Author Topic: REAR PINION ANGLE QUESTION!?  (Read 2655 times)
95runnerNW
  • Male Posts: 44
  • Member since Jul '09
  • Rock Nibbler
« on: Jun 11, 2010, 11:47:17 AM »
Doing a coil to leaf conversion on my 95. Read different stuff about where to put my rear pinion angle. High angle says if I dont have a double cardan(I dont) then to put the flanges parallel, but I also read to point the pinion flange at the T case then weld the perches?? Any help would be appreciated
joeycool00
  • Turtle Points: -10
  • Male Posts: 315
  • Member since Mar '10
  • 3rd f.a.s.t yes i'm a Jar Head!and proud of it
Re: REAR PINION ANGLE QUESTION!?
« Reply #1 on: Jun 11, 2010, 11:53:36 AM »
line it up with the t case thats it... i did the same thing
life is hard, but it is harder if your stupid!
Love wheeling in  central washington state, wouldn't have it any other way!
joeycool00
  • Male Posts: 315
« Reply #2 on: Jun 11, 2010, 12:01:31 PM »
HDcruiser
  • Turtle Points: 10
  • Male Posts: 580
« Reply #3 on: Jun 11, 2010, 12:02:04 PM »
I rolled mine up i think it was 13 degrees, and have no vibration. Before i rolled it up i did vibrate.
95runnerNW [OP]
  • Male Posts: 44
  • Rock Nibbler
« Reply #4 on: Jun 11, 2010, 12:09:54 PM »
thanks will do..i got 6" springs hope the rear dont sit too high i'm sure it'll settle tho..
HDcruiser
  • Turtle Points: 10
  • Male Posts: 580
« Reply #5 on: Jun 11, 2010, 12:32:25 PM »
I rotated my brothers 4runner at the same angle and he has 5" springs.  :greengrin: His has been on the road with the same set up for about 10 years with no driveline issues.
95runnerNW [OP]
  • Male Posts: 44
  • Rock Nibbler
« Reply #6 on: Jun 11, 2010, 12:49:08 PM »
thanks man i got my angle finder ima go with 13
Ironloki
  • Turtle Points: -3
  • Male Posts: 87
  • Member since Dec '09
  • I cant drive 55.. literally.... its so slow
« Reply #7 on: Sep 20, 2010, 08:20:59 PM »
hey im havin the same issue, is the 13 degrees at full drop? I got 13 at drop and 10 with weight on new springs..should settle to maybe 8??  :dunno: doesnt seem too drastic, ive seen worse!
If you stop evolving, you cease to exist.
Project bella👇
http://board.marlincrawler.com/index.php?topic=64106.0;highlight=bella
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
« Reply #8 on: Sep 24, 2010, 08:11:45 AM »
The double cardinal lets you run the pinion at any angle you want because it uses two u joints to counter any vibration, if you dont use it you need to run the two u joints with the flanges parallel if you dont want vibration.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
Last post Nov 02, 2004, 06:34:22 AM
by WHITE_TRASH
Last post Feb 27, 2006, 01:37:49 PM
by IronClad
Last post Jul 23, 2007, 02:02:00 PM
by DTB
Last post Nov 23, 2007, 09:29:57 AM
by Volcom
Last post Jul 11, 2016, 12:05:24 PM
by H8PVMNT
