Author Topic: Pinion Angle  (Read 3590 times)
Yogatoy
  • Male Posts: 50
  • Member since Apr '07
  • Chris's Rig
Pinion Angle
« on: Jul 19, 2007, 04:11:04 PM »
Can Anyone help me. I just bought the 5" lift and I need to know how to set up the pinion angle for the rear axle. what angle Do I set it at and Do i have to wait to set the pinion angle after I get the body back on the frame or can I set it with Just the frame. Please help. My truck is a 84, extra cab
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
Re: Pinion Angle
« Reply #1 on: Jul 19, 2007, 04:17:02 PM »
u want the pinion to be pointed directly at the transfer case taking into account the springs settling. U dont need the body on the frame. I am assuming you are cutting off and welding on new perches
Quote
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: Pinion Angle
« Reply #2 on: Jul 19, 2007, 04:23:04 PM »
best way to do this is loosely mount the axle under the springs....(ubolts finger tight) with the perches sitting on top jack it up.  Use another jack to jack the front of the pinion up to desired angle
Quote
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
Re: Pinion Angle
« Reply #3 on: Jul 23, 2007, 11:45:29 AM »
If I were you I would mock it up, as I have the 5" springs on mine and did not have to change my angle at all.
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: Pinion Angle
« Reply #4 on: Jul 23, 2007, 01:22:25 PM »
i have the 4 inch springs and moved my pinion up a good couple inches by rewelding the perches
Quote
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: Pinion Angle
« Reply #5 on: Jul 23, 2007, 01:28:36 PM »
Is it not best to have the pinion pointing just slightly below the center line of the t/case output flange? That way under compression/axle wrap, it doesn't go too far beyond the centerline.
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: Pinion Angle
« Reply #6 on: Jul 23, 2007, 01:39:01 PM »
i dont know..are you asking me? can the suspension compress that far that the pinion would be above the output flange?
Quote
  • Administrator
  • 511:1 Club
Re: Pinion Angle
« Reply #7 on: Jul 23, 2007, 01:59:08 PM »
Of course. I mean, it's all being stupidly technical, the truck will still perform all the same, but if you have the option to alter the angle, then we always recommend to point the pinion just slightly below the center line of the t/case output shaft.
:twocents:
DCabTaco
  • Turtle Points: 49
  • Member since May '06
Re: Pinion Angle
« Reply #8 on: Jul 23, 2007, 02:01:43 PM »
I've read that too, unless you have a traction bar.
04 SCed DCab Taco
85 4runner
97 Civic (DD)
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: Pinion Angle
« Reply #9 on: Jul 23, 2007, 02:02:00 PM »
:twocents:
thanks mike i didnt know that  :smooch:
Quote
Last post Nov 23, 2007, 07:39:38 PM
by 79coyotefrg
Last post Nov 23, 2007, 09:29:57 AM
by Volcom
Last post Jan 13, 2008, 06:43:22 PM
by OOPS
Last post Jul 26, 2009, 10:46:04 PM
by potter85
Last post Jul 11, 2016, 12:05:24 PM
by H8PVMNT
