1980 Toyota 4x4 Nice project for a Northeastener
Started by Cracker, May 25, 2010, 04:36:18 AM
Cracker
1980 Toyota 4x4
SOLD SOLD SOLD
NEW PRICE: $1000 OBO
The Good:
Has 22R with 20R head.
Unknown header.
Someone went thru this motor before I got it, and probably added a higher performance cam, and other stuff.
I added a higher flow 22R turbo oil pump and new crank seal from Ted at enginebuilder.com.
Also has been converted to power steering using an 84 4runner box & pump.
Has Budbuilt.com 63" Chevy spring brackets tack welded on. (Unfortunately, I never got to complete the swap.)
Also has one of the first ever Budbuilt double T-case crossmembers made for the 1st gens.
I swapped in a turbo R151 trans, that was a dealer rebuild I picked up, but never got to swap in a 2nd Tcase.
Unknown 3" or 4" springs.
Supposedly has EZ or Lockright locker in the rear.
CLEAN, solid frame for a truck in the NE. It was originally a NC or SC truck, I forget which.
Has only seen 2 or 3 NY winters. Frame still has lots of paint, and only surface rust on it.
Has an interior, bolt-in roll cage.
SR5 gauge gauges.
Custom made center console.
4pt harnesses.
Diamond plate across-the-bed tool box.
15"x10" Centerline deep dish rims.
Clean title.
Now the Bad & Ugly:
The tires are old 33x15x15.5 Swamper TSX/SLs, but are close to bald, and have been siped... NOT street legal.
Body is solid, except the windshield seal came loose, some rust.
Bed is starting to bubble some rust in the floor-to-bedside seams.
Has an Offenhauser manifold, but needs a carb. A Weber would be a good choice.
The two interior plastic covers for the steering column are missing.
The PO enlarged the floorboard hole for the shifter boots, probably to swap out a 4spd for the 5spd it had when I got it. Needs a cleaner piece welded in so the shift boot base fits properly.
Its an 80, but has the headlights/surrounds from an 83, also put in by the PO.
Also, the paint job is ugly...LOL
I need this gone NO later than May 31.
$1000 OBO
Located in western NY, south of Rochester, close to I390.
Cash, Paypal or money order.
Art
99 Taco
80 Hilux - 20/22R Hybrid, Dual Mikuni's, R151 trans, Budbuilt X-member
74 FJ40 "The Project"
PadawanYota_Stovy
Man that is a sweet rig. Keep and use for a DD :thumbs:
Stats : 85 Toyota 22RE , 3" body lift, 32" wild country's, Duel Marlin, Lock rights front and rear, full inside cage.
I drive , I wheel , I crawl , I am Toyota
Cracker
I wish I could keep it... New landlord says it has to go...
No interest in it, so I guess this one is going to the junkyard :(
Art
99 Taco
fade
strip it out before the wreckers those clusters are worth some and the axles and grill and all that stuff. Pretty much send them a frame is what I would do. If you got space to put the parts that is. No luck on the craigslist? Wish you were in oregon i'd be all over it.
86 mini truck 18" rays
09 highlander
70 suburban
Mavericks
You should have no problem selling it! this would be a great starter rig for someone!
1985 toyota SR5, 22re,  5.29's locked front and rear, duals with twin stick, longfields.
motormouth559
fade
any one need first gen parts? I need a axle lets make a road trip I'm in oregon.
09 highlander
70 suburban
zr2runner
dont junk it yet... i will be in the syracuse area and i might just take it off your hands... just PM'd you
Cracker
Art
99 Taco
Cracker
Art
99 Taco
