I have the big compressor. Used teflon tape. The only thing that i have in doubt it for the big 2 prong pressure sensor, i couldn't determine which wire went to which prong. Is there a possibility that i screwed that up...
Shouldn't air just build up into the manifold with JUST the compressor switch energized? with the front locker switch in off shouldn't that cause the solenoid to be shut and therefore no flow? ill have to try the diff breather air flow next time
...why buy when you can build?
mine cycles about once about every hour with the locker disengaged. Never had the locker engaged for more than 5 minutes, and it didn't cycle. FYI I have the small compressor.I would build a test jig like it says in the instructions, or like ZUK has, and test the locker itself. Since Marlin built it I would assume that its good, and for your sake I hope that it is. It would be much much easier to fix a leak in the air lines/fittings than to yank the diff and re-do the o-ringsmy .02PZ
Ive got the feeling it's all ready installed
Started by 80crawleryota « 1 2 3 » Project Research and Build-Ups
Started by toeyota Engine
Started by joblo Engine
Started by Kurlee Daddee Toyota Pickup/4Runner Tech 1979-95
Started by PeterPaul383 Engine
