Author Topic: Metal cutoff band saws  (Read 3732 times)
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
« on: Mar 20, 2010, 02:31:11 PM »
I have a cheap harbor freight 64 1/2 metal cutoff bandsaw. Ive had it for awhile, but as of lately I keep breaking blades, a lot after less then a dozen cuts. It never did this in the past, I made sure everything is good with the saw itself. So Im thinking that that small of a blade length is the problem. Anyone recommend a good saw to get? Im tired of this.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: Metal cutoff band saws
« Reply #1 on: Mar 20, 2010, 02:35:32 PM »
What about getting better blades (not from Harbor Freight)....
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
junya92toy [OP]
  • Male Posts: 1,500
  • Drinking me beer
« Reply #2 on: Mar 20, 2010, 03:06:39 PM »
I have been getting better blades. The last 3 that broke in less then 12 cuts are good blades from a actual tool supply place, bi metal blades too.
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« Reply #3 on: Mar 20, 2010, 04:42:55 PM »
your talking about a portable band saw right? i have a millwakee, its the :pokinit:. i can get at the very least 100 cuts per blade
UA 342
STEAMFITTERS
junya92toy [OP]
  • Male Posts: 1,500
  • Drinking me beer
« Reply #4 on: Mar 20, 2010, 05:00:52 PM »
No the horizontal/ vertical 4x6 saw.
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #5 on: Mar 20, 2010, 07:02:22 PM »
Are they breaking because they're too tight or too loose and binding?
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #6 on: Mar 20, 2010, 07:13:22 PM »
Link to Harbor Freight so we can see which one you're talking about........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
yjay
  • Male Posts: 555
  • Member since Feb '09
  • SFA Station Wagon
« Reply #7 on: Mar 20, 2010, 07:35:57 PM »
I have a friend with a HF wet bandsaw. Initially he had a lot of problems with it and found that it was because the guides were out of adjustment and not holding the blade straight. He went through and aligned and tightened the little bearings and all and has had no other issues other than the pump for the coolant went out. He just uses it without the coolant now.
We have a small Jet 4"x6" saw at work that is a gem. No coolant which is fine for most people. I think it was around $350. Morse blades seem to work well.
« Last Edit: Mar 20, 2010, 07:41:50 PM by yjay »
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
junya92toy [OP]
  • Male Posts: 1,500
  • Drinking me beer
« Reply #8 on: Mar 20, 2010, 10:02:22 PM »
the guides seem straight and ya its the same size as that jet bandsaw. It will cut very very square but the blades break. I tighten them pretty hand by hand not so much as im do it as hard as i can but very firm.
 I think im going to get this
http://www.cpojettools.com/products/414454.html?ref=jettools414454
« Last Edit: Mar 20, 2010, 10:08:11 PM by jerry92toy »
possume22
  • Member since Apr '09
« Reply #9 on: Mar 21, 2010, 03:27:25 PM »
sound like cheap blades or you got it to tight
junya92toy [OP]
  • Male Posts: 1,500
  • Drinking me beer
« Reply #10 on: Mar 22, 2010, 09:21:14 AM »
Honestly buy hand you cant over tighten them. On the bigger saws that use a one inch blade you really tighten them down with a big handle.
possume22
« Reply #11 on: Mar 22, 2010, 05:21:17 PM »
hope you figure it out my freind has one from harbor freight if he buys cheap blades its few cuts and break good luck
junya92toy [OP]
  • Male Posts: 1,500
  • Drinking me beer
« Reply #12 on: Mar 24, 2010, 07:36:15 PM »
I got a couple of home depot blades, seems to cut good now. I know they have bad lots of blades. I exchanged the higher quailty ones for new ones,  havent used them yet.
possume22
« Reply #13 on: Mar 26, 2010, 06:54:59 PM »
good to here some shops can reweld some if there broke clean just a thought have seen lots break at the weld where put together
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Member since Feb '05
  • Annihilation Fabrication
« Reply #14 on: Mar 26, 2010, 07:15:48 PM »
sounds like to much weight on the cut ?  try backing off on the "pressure" it will take a little longer to cut but thats better than breaking blades
Do you need a Hammer?
junya92toy [OP]
  • Male Posts: 1,500
  • Drinking me beer
« Reply #15 on: Mar 26, 2010, 09:59:27 PM »
I dont have any pressure on it. Just enough. Usually when too much pressure it wont cut straight.
junya92toy [OP]
  • Male Posts: 1,500
  • Drinking me beer
« Reply #16 on: Apr 10, 2010, 07:13:55 AM »
I still couldnt get it to stop breaking blades so I said screw it and got this.
Last post Apr 29, 2006, 07:26:41 PM
by CTENG in KS
Last post Jun 23, 2007, 06:47:49 PM
by Shamb
Last post Dec 30, 2007, 10:57:41 AM
by topar
Last post Apr 22, 2008, 11:07:37 AM
by SHSTL_82
Last post Jul 05, 2008, 10:12:34 PM
by yota_krawler
