Toymin8r's 1989 1UZFE Lexus v8 Powered Pickup
Started by Toymin8r, March 15, 2010, 09:18:47 AM
muddytaco
who says im puttin it in a taco?? just kiddin i am, i want to put the 3rz in the 4runner and put the 1uzfe in the taco, are you in arkansas?
95 tacoma 5" revtek/bilstein detroit locked 9" with drilled and slotted rotors front and back, 8000# mile marker winch, 16" crager crawlers, too much other crap to mention
96 t100 2wd (soon to be sasd i hope) - dead
85 efi 4runner
01 sequoia
Toymin8r
Quote from: muddytaco on June 02, 2010, 06:48:36 PM
No, St. Louis, MO.  if you know where a 30k mile 1uz doner car is and don't want it let me know.  I want to do another swap with an 88 4Runner I have next.
muddytaco
im going to buy the car for sure no, i just never looked to see, i dont really know where to find info on what will fit what as far as trans and t cases, whats it gonna cost for him to wire your truck?
85 efi 4runner
01 sequoia
Toymin8r
:woohoo:  Got my truck back today.     I have to put everything back together and tidy up some of the wires but the biggest part is done.
here is a short video
http://www.youtube.com/watch?v=whvJbEh5q8o
wslytoy
Quote from: Toymin8r on June 06, 2010, 03:56:34 PM
maybe it's just me, but you can't even hear it at the tip of the exhaust. Which to me, isn't a bad thing.
Toymin8r
It has a nice low rumble at idle but its a Flowmaster so it gets kind of loud under hard acceleration.  It also has a small exhause leak at one of the flanges because I think I warped it when I welded it.  I need to re-surface the flange with a belt sander.
muddytaco
85 efi 4runner
01 sequoia
Toymin8r
Quote from: muddytaco on June 06, 2010, 07:50:00 PM
how much did it run you to get it wired??
I'd rather not say exactly because the guy who did it may have other similar wiring jobs in the future but it was in the $500 range.  Its on par with what phoenix tuning charges for a 1uz swap harness only my local guy did a whole lot more than what phoenix tuning could have done because he had my truck.  It ended up being a little more work that what he intended but both he and I are extremely happy with the results.
minicrawlin
awesome man, all i can say it awesome! thats the way to go it seems! i wanna do that badly now! good work man! get it put together and do some crawlin!!!
the rocks Rock in South D SON!
95runnerNW
lilbuddy
This is legit dude....... Showed a guy at work and he was stoked on it too...
RIP Kyota.... you are the man
GET IT!!!
gtoyonrocks
That's sweet. I'm currious how your third members will hold up with that set up.
Toymin8r
gtoyonrocks
Your post has got me looking at sc400's. I think I'm going to get one for a dd... I think the conversion you did is awesome but I would rather put that in a 2wd or an old celica. My next engine conversion is going to be a 1.9 tdi.
Toymin8r
Got an axle from a 1999 4Runner.   Its 3" wider than my 89 axle and is closer to the width of my FJ80 front axle.
A plasma cutter makes short work of the brackets.
KDXSR5
What is the difference in width front to rear with this new rear axle?
Toymin8r
Quote from: KDXSR5 on July 03, 2010, 02:53:03 PM
The standard 79-85 solid front axle is 55".  The standard 86-95 IFS rear axle is 58".  The 96-03(maybe newer) is 61".  The FJ80 landcruiser is 63.5"
LilChief87
damn sounds healthy man wana do that swap into my 1st gen for me haha
Toymin8r
46&2
Atta boy, get your next project lined up before you are even finished with your current project. Hell yea  :gap:
Toymin8r
Quote from: fortysixandtwo on July 04, 2010, 03:28:04 PM
Of course.  I got 3 or 4 more behind that.
46&2
Quote from: Toymin8r on July 04, 2010, 06:03:56 PM
Yeah, first is to Total Chaos the old lady's third gen extra cab. After that it is Toyota 4.7L V8 powered 85 Supra. After that.... trying not to get too ahead of myself :gap:
KDXSR5
Ah I only have one project :down:
well I guess I have my dirtbike rebuild, and a SAS for my GMC, and.... :gap:
Toymin8r
I want to do a big blocked Chevy truck using a set of unimog axles I got and the biggest boggers I can afford.  All I need is a rust free body for that.  I got the whole drivetrain already.  Then I got a 1979 Bandit edition Trans am I want to restore.   Then a 1970 Chevelle SS396 that I've had for over 20 years.  I' have severalmore if I had the room to store all of it.  :thud:
gtoyonrocks
Toymin8r
the_white_shadow
gtoyonrocks
Yea, I'm in the same boat. I'm working on retubing the front of my rock crawler. I have a 92 toy that is a dd that needs paint and a new clutch and I have a 1 ton k5 blazer I'm building. Lot of work to do and not enough time or money.
swapped89
will a diff from an 89 rear axle fit in the axle housing of a 1999? probly not but just wonderin if you knew? :dunno:
p.s.   truck sounds awesome! that things gonna be alot of fun :thumbs: :beerchug:
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
