Author Topic: Toymin8r's 1989 1UZFE Lexus v8 Powered Pickup  (Read 118737 times)
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
Okay so just use the lexus trans with the taco output. leave everything else the same and now you don't need that adapter. Correct?
Correct.   You will still need to cut the output shaft on the Lexus transmission and you will still need whatever adapter you would use on the back of your taco to get your gear driven transfer case.  Unless you are putting on big tires I'd just stick with the taco transfer case and then you won't need any adapters.
Quote
Toymin8r [OP]
  • Turtle Points: 50
  • Male Posts: 929
Can't get the videos to embed but here are a couple of short videos crawling "Double Whammy" at Southern Missouri Off Road Ranch.  unfortunately the camera angle doesn't shot the ledges and how steep the hill is.
https://www.facebook.com/video/embed?video_id=659244714100442
https://www.facebook.com/video/embed?video_id=659245224100391
« Last Edit: Oct 02, 2013, 07:37:21 PM by Toymin8r »
Quote
tyes
  • Turtle Points: -10
  • Male Posts: 238
  • Member since May '09
DId you ever had issues with your wiring harness?
86 T4R V8 1UZ-Fe
Toymin8r [OP]
  • Turtle Points: 50
  • Male Posts: 929
No, never had any issues with wiring.
Quote
zidaro
  • Turtle Points: 480
  • Male Posts: 527
  • Member since Oct '02
  • Mo Chi Chu!
video ended just when that 1uz was starting to wake up :)
'87runner.
'10 Crewmax
'05 CRF450x
http://www.4wheelunderground.com/
TONIK- Mammoth Lakes
tyes
  • Male Posts: 238
mine swap is almost done, working on drive line and some TLC
86 T4R V8 1UZ-Fe
Toymin8r [OP]
  • Turtle Points: 50
  • Male Posts: 929
Quote
ajordan1975
  • Turtle Points: 8
  • Male Posts: 1,004
  • Member since Jun '07
  • i think i'm cool
The ladies seen to be enjoying them selves
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
Awesome
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
Yota Steve
  • Member since Jul '14
Awesome build I'm about to do 1uzfe swap myself in a 79 4wd. The engine is out of a 96 LS400. Do you have any tips on the wiring? I will be using the w56 trans with it.
Toymin8r [OP]
  • Turtle Points: 50
  • Male Posts: 929
About my only suggestion is to NOT use a 96 or newer version of the engine..lol.    I believe 1996 was the year they switched over to ODBII Emissions and ECM is much more sensitive to any disruption in the system.    It may not care but I don't know.   Just get as much of the donor wiring as you can.
Quote
Toymin8r [OP]
  • Turtle Points: 50
  • Male Posts: 929
Quote
OVRAROK
  • Turtle Points: 26739
  • Male Posts: 3,523
  • Member since Dec '10
nice exhaust tone, that v8 sounds nice
Last post Jul 08, 2008, 04:41:59 PM
by Toymin8r
Last post Mar 11, 2009, 06:42:43 PM
by joey0712
Last post Jul 01, 2009, 10:21:34 PM
by 84socal
Last post Aug 27, 2015, 06:25:31 AM
by Rocksurfer
Last post Jun 06, 2016, 01:45:16 AM
by Aznwolf118
