Yes sir, but I would lose some turning radius wouldn't I ?
yeah you could also lose your life when your pitman arm snaps in half from the fatigue of heating and bending cast steel!
yeah you could also lose your life when your pitman arm snaps in half from the fatigue of heating and bending cast steel! As far as i know, no companies make an arm that drops more than stock. Usually about 99% of the time pitman arms with less drop are acuired so they dont come in contact with the leaf springs. Your truck must be pretty tall?
why dont you stand the box up and move it forward? or is there a specific reason why you want to have it sitting down like that pic?
I've never known ProComp to offer a monotube shock, typically they are similar to Rancho's have no rebound or compression. I would consider purchasing something like Fox or Sway-Away, or even a better Bilstein. Try Polyperformance, I know this is a more expensive way of fixing the problem but shocks are not just shocks, they have a purpose. You may even try adding another shock, just double up. Same length same size.
Started by nowhitefenders Parts For Sale
Started by 12runner Parts For Sale
Started by wakkjobb Engine
Started by 81yotalove Engine
