Author Topic: Camber not Caster  (Read 2635 times)
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
Camber not Caster
« on: Feb 17, 2010, 12:50:40 AM »
Any body know what a mini truck knuckle is set at from the factory???
Yes I've looked in the book, but it isn't there.   :screwy:
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
zippo
  • Turtle Points: 550
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
Re: Camber not Caster
« Reply #1 on: Feb 17, 2010, 01:28:43 AM »
Jack the front up. Slap an angle finder on the back side of the rotor/Spindle/hub? If you wait till the morning i can check.
Ive heard they even make camber shims for the solid axle.
If you see it, its for sale.
TacoRunner [OP]
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #2 on: Feb 17, 2010, 02:16:51 AM »
 :headscratch:    Im not going out a 2am besides, whats the angle finder going to do for me attached to the rotor? I need camber not caster.
not for a toy
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
« Reply #3 on: Feb 17, 2010, 08:39:17 AM »
TacoRunner,
I just found some alignment specs in my '85 FSM.  They are in the back in the specs section under "front axle."
Camber is 1* plus or minus 45'.
Caster has 2 settings - one for a truck and one for a 4runner.
                truck= 2* 15' plus or minus 1*
                4runner= 3* plus or minus 1*
SAI (steering axis inclination) is 9*30' plus or minus 45'
TacoRunner [OP]
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #4 on: Feb 17, 2010, 09:12:40 AM »
You are my hero, infact now I see that my 1am drunken post was wrong to begin with,  :smack: it is the steering inclination I need not the camber any ways. So in a none  :stopit: kinda way I :love: you. This may be safer  :beerchug: yep lets just stick with that one.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
« Reply #5 on: Feb 17, 2010, 09:15:37 AM »
Are you doing a cut and turn?
TacoRunner [OP]
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #6 on: Feb 17, 2010, 09:18:57 AM »
ha, NO. Im doing a chart on scrub radius for the mag, and I want to chart/graph what it takes to get zero scrub radius from a given tires size.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
« Reply #7 on: Feb 17, 2010, 09:44:23 AM »
Cool.  I've heard the term scrub radius before, but don't remember what it is or why it's important.   It will be nice to get a little refresher coarse.  I took that alignment classes too long ago, and now without me working on cars for a living anymore, I'm getting a little rusty.
zippo
  • Male Posts: 1,556
    • oppiz.net
« Reply #8 on: Feb 17, 2010, 02:32:29 PM »
not for a toy
As far as i know camber is the tilt in and out of the wheel.
[img width= height=]http://www.driftclub.gr/v3/images/stories/faq/camber_angle.jpg[/img]
and caster is the angular displacement from the vertical axis
[img width= height=]http://autowarrantycontract.com/_images/GlossaryImages/art_Caster.gif[/img]
So the rotor is on the same camber as the wheel and would give you the angle? Am I wrong?
Also cool idea, If you had a billet high steering arm, you could ofset the pin and change the camber? I dunno If it would be a good idea or help, but cool to think about.
Props for BUDDERS for just throwing that out.
Funny camber video!
http://www.youtube.com/watch?v=g99-gPXpZ9A&NR=1
« Last Edit: Feb 17, 2010, 03:03:44 PM by zippo »
TacoRunner [OP]
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #9 on: Feb 17, 2010, 03:02:26 PM »
Ya, I was drinking to much and ment steering axis inclination, not camber, my bad. I should stop smoking crack too.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
« Reply #10 on: Feb 17, 2010, 03:03:40 PM »
Zippo, you sir are correct.  And if you're wondering about that post by TacoRunner, this might explain things:
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
« Reply #11 on: Feb 17, 2010, 07:14:06 PM »
taken directly from wikipedia for those that dont know....(for some reason chassis was one class i remembered from school)
scrub radius is the distance in front view between the Steering Axis and the center of the contact patch where both would theoretically touch the road. The steering axis is the line between the top pivot point of the hub and the lower ball joint of the hub. On a MacPherson strut, the top pivot point is the strut bearing, and the bottom point is the lower ball joint. The inclination of the steering axis is measured as the angle between the steering axis and the centerline of the wheel. This means that if your camber is adjustable within the pivot points (i.e. Volkswagen) you can change the the scrub radius, this alters the width and offset of tires you can safely run on your car.
Ok now lets talk about Ackerman Angle  YAY
Those are some huge welds!
Tillamook, OR
TacoRunner [OP]
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #12 on: Feb 18, 2010, 10:34:28 AM »
Sorry Zippo, like I said, it was to late for me and had few to many. Sorry dude.
zippo
  • Male Posts: 1,556
    • oppiz.net
« Reply #13 on: Feb 18, 2010, 01:33:32 PM »
No Prob! We all have those drunken moments. But I really would stay off the crack, heroin perhaps?
Last post Jun 08, 2002, 08:29:33 AM
by BigMike
Last post Aug 19, 2004, 07:39:15 PM
by WHITE_TRASH
Last post Aug 25, 2005, 07:53:34 AM
by FIREBALL
Last post Sep 21, 2008, 06:47:21 AM
by llamas
Last post Nov 01, 2008, 08:45:16 AM
by johnyreb69
