Author Topic: Elkotoy build  (Read 2818 times)
ElkoToy
  • Member since Jan '09
Elkotoy build
« on: Jan 16, 2010, 05:34:35 PM »
I bought all the parts to start this build over a year ago after a few month of tinkering I ended up jobless. Now finaly back to work I have money to build. I bought someone start to a truck that they gave up on. This is what I brought home an '82 fram with 5" springs and a 21R motor.
ElkoToy [OP]
Re: Elkotoy build
« Reply #1 on: Jan 16, 2010, 05:44:30 PM »
I picked up a '87 turbo truck missing the motor for 500 bucks. Mounted the extended cab on the shortend 80's frame will leave 5' for a flat bed. this is how it sit now.
ElkoToy [OP]
Re: Elkotoy build
« Reply #2 on: Jan 19, 2010, 04:11:56 PM »
Pick up a 85 supra with a good 2.8L in it Now time to dive it to the harness. It looks like about most of it can go. Good thing it came with the Toyota service manual.
axled89
  • Turtle Points: 296
  • Male Posts: 2,526
Re: Elkotoy build
« Reply #3 on: Jan 19, 2010, 08:33:42 PM »
looks like a project.   :biggthumpup:
i love oregon wheelin.
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
  • Member since Dec '06
Re: Elkotoy build
« Reply #4 on: Jan 19, 2010, 08:59:55 PM »
I can't wait to see how it turns out. Please post your pics.
axled89
  • Male Posts: 2,526
Re: Elkotoy build
« Reply #5 on: Jan 19, 2010, 10:41:11 PM »
X2
ElkoToy [OP]
Re: Elkotoy build
« Reply #6 on: Jan 21, 2010, 11:55:31 AM »
Holy Sh*t there is a lot of wiring on an 85 supra. and most of it can go but you have to figure out witch ones it is.
bigman
  • Turtle Points: -10
  • Male Posts: 201
  • Member since Jan '05
  • punish all jeeps
Re: Elkotoy build
« Reply #7 on: Jan 22, 2010, 04:50:10 PM »
looks like lots of fun
MONTANA BOYS KICK A$$
IF U CANT DUCK IT F IT
1Knucklehead
  • Male Posts: 15
  • Member since Jan '10
  • Your Fagged Off
Re: Elkotoy build
« Reply #8 on: Jan 23, 2010, 05:20:52 PM »
Man that is a lot of wires good luck.
If your going to run Chevy parts buy one.
ElkoToy [OP]
Re: Elkotoy build
« Reply #9 on: Feb 14, 2010, 10:54:33 PM »
Made some progress got all the wiring gone through and down to the bare minimum to run. I also got the motor pulled and on the stand. Dose anyone know the supra has rack and pinion steering is there any difference in the power steering pumps? Will it work on a pick up steering box?
ElkoToy [OP]
Re: Elkotoy build
« Reply #10 on: Feb 15, 2010, 02:09:39 AM »
OK with the help of a couple of factory Toyota repair manuals I found out that a 4x4 power steering pump put out around 925 Psi and so dose the 85 supra I took the motor from. The thing I found odd was it say that a 4wd power steering pump put out the 925 psi but a 2wd power steering pump of the same year put out 1070 psi. Anyone know way a 2wd would put out more?
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
Re: Elkotoy build
« Reply #11 on: Feb 16, 2010, 09:20:51 PM »
That is odd. I have ran power steering pumps off of toyota Celica's in my trucks with out ever having an issue. If I new that there was one out there that put out more psi I would have went with that.
ElkoToy [OP]
Re: Elkotoy build
« Reply #12 on: Feb 21, 2010, 10:57:16 AM »
OK for all of you who have done supra motor swaps. When putting the 5mge into the trucks what is the best oil pan to use. I have heard that the supra one will work then I heard to swap it with a cressida pan or to use the one from an 7mge. Witch one is the best way to go?
Last post Sep 06, 2004, 09:56:32 PM
by freds40
Last post Aug 14, 2004, 06:53:08 PM
by yotaboy79
Last post Dec 19, 2006, 06:05:03 AM
by yotadork83
Last post Jan 20, 2007, 10:13:46 AM
by toyhunter
Last post Nov 30, 2015, 01:11:55 PM
by Kaos III%
