Author Topic: quick question about body lift  (Read 1834 times)
ZombieHunter
  • Member since Nov '09
« on: Jan 13, 2010, 05:00:55 PM »
I have a 3 in NIB and going to cut down the blocks to 2 in. Now do i just cut the bolts down and inch also and thead them?  For people that have installed these before is there anything wrong with this? 1984 truck.
Doof
  • Turtle Points: 41
  • Male Posts: 3,205
  • Member since Apr '07
  • establised summer of 89
Re: quick question about body lift
« Reply #1 on: Jan 13, 2010, 05:02:35 PM »
you tell us, if you can cut the bolt down and have enough threads left, then it should be legit. if your going to have to re-thread then it might be easier to buy new bolts an inch shorter
edit:
but cutting the puck down is no problem. assuming you can cut straight then it will be fine
Dr Phat
  • Turtle Points: 305
  • Member since Oct '09
« Reply #2 on: Jan 13, 2010, 05:05:16 PM »
Cant you just install the BL with the same bolts, thread the nut on, tighten down and then cut the bolt?
GONZO97
  • Turtle Points: 48
  • Male Posts: 612
  • Member since Apr '09
  • travel the path less taken
    • Christian's Mattress Xpress
« Reply #3 on: Jan 13, 2010, 05:16:20 PM »
depends how deep the threads are ... because if he cant thread it tight enough then he'll need new bolts as stated byDoof
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
ZombieHunter [OP]
« Reply #4 on: Jan 13, 2010, 05:20:43 PM »
I will just wing it after i cut the blocks.
Doof
  • Turtle Points: 41
  • Male Posts: 3,205
« Reply #5 on: Jan 13, 2010, 05:25:19 PM »
best way to learn at times
thegoofster21
  • Male Posts: 1,644
  • Member since Mar '08
  • HIT IT HARD!!!
« Reply #6 on: Jan 13, 2010, 05:29:48 PM »
b/l are guy get rid of it if you can :twocents:
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
Dr Phat
« Reply #7 on: Jan 14, 2010, 09:38:33 PM »
Body drops is where its at. Haha.
89sastoyo
  • Turtle Points: 148
  • Member since Jan '09
« Reply #8 on: Jan 15, 2010, 12:48:50 PM »
why would you have to wing it just measure and inch shorter on the bolt from where its sitting you you have thread than you are fine if not spend 10 bucks on some bolts and use your old washers and what not. you should only have about 2" of shank or what ever you wanna call it and that should work the body lift is 2 and then the bushing and sheet metal.. Simple mathmatical equations can help.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
Last post Mar 31, 2005, 10:37:58 AM
by 86 4runner
Last post Apr 26, 2005, 05:28:21 PM
by germ
Last post Jul 02, 2005, 07:50:28 PM
by 79coyotefrg
Last post May 15, 2006, 06:06:33 PM
by Stump
Last post Jun 28, 2007, 09:08:34 AM
by 79coyotefrg
