Author Topic: 86 22re dual battery and dual alternators ?!  (Read 16766 times)
gwbaker
  • Turtle Points: 2
  • Male Posts: 27
  • Member since Jul '09
Re: 86 22re dual battery and dual alternators ?!
« Reply #30 on: Dec 28, 2009, 05:40:09 PM »
sorry cant figure out how to post pics, keeps saying they are to big....
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #31 on: Dec 30, 2009, 12:01:15 PM »
email it to me or  put it on photo bucket
HEY,  you want to go to a awesome offroad event??  http://www.ttora.com/forum/showthread.php?goto=newpost&t=143476
gwbaker [OP]
  • Turtle Points: 2
  • Male Posts: 27
« Reply #32 on: Dec 30, 2009, 06:08:21 PM »
ok, i got it figured out, it was the batteries, put a new one in today and no problems, the batteries are still good they will hold a charge but they just wont work for this application i guess. i took both batteries and hooked them up to a spotlight for over 30 minutes and they both seperately hold over 12 volts, oh well ill keep them as spares for other vehicles..... thanks to everyone for their help, best board ever.... and im goin to check into that event id love to go....thanks again
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #33 on: Dec 30, 2009, 11:01:23 PM »
Glad you got it worked out!  It was suggested to you to load test the batteries, which is just like trying to start the truck or run accessories.  Take those batteries to the recycler and run away with the money, don't let them leave you stranded cause they will  ;)
And I would seriously consider switching to a high output 1 wire gm alternator too.  Dual alts is totally not necessary when you can achieve better results with 1 very simple, easily sourced and replaced alternator  :thumbs:
gwbaker [OP]
  • Turtle Points: 2
  • Male Posts: 27
« Reply #34 on: Dec 31, 2009, 04:23:58 PM »
yes soon i will upgrade to a new alternator, i found one that is 130 amp for 89.95 with 19.95 shipping with no core charge, and a 1 year warranty, that bolts right up, no modification, factory replacement.
myyota
  • Turtle Points: -1
  • Male Posts: 120
  • Member since Nov '06
« Reply #35 on: Jan 01, 2010, 06:40:56 PM »
You can get a 150 amp alternator from mralternator.com , and its plug and play.
86 4Runner
Solid Axle Swap, 5'' Of Lift, 37x12.50-15 MTR Tires, 5 Speed Manual Swap, Inchworm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5''Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears and an ARB, Downey Header, Optima Battery, Trail Gear Sliders.
  • Male Posts: 9,757
« Reply #36 on: Jan 02, 2010, 08:14:17 PM »
Oldest they list one for is 89 though.
dntsdad
  • Turtle Points: 8
  • Member since Jan '09
    • My 3.4 swap into a 92 pickup
« Reply #37 on: Jan 02, 2010, 08:47:21 PM »
Ya I would stay away from the dual alternators if it were me. An upgraded alternator and an isolator and two GOOD batteries would be a better, no hassle setup. Remember, a 130, 150 whatever amp alternator doesnt put out that amperage all the time. It simply has that capability.....as needed just like a 400hp 68 Mustang Fastback wont be putting out 400hp cruising down the road at 15mph. Bigger(amperage) can never be bad.(thats what she said)
If you do dual alternators I would wire the lights through a relay of course but also have that same relay trigger another relay to excite the alternator as well if you are not going 1wire. I could see me kicking on the lights and forgetting to do the same for the alternator.
92 Toyota x-cab, 3.4 swapped, R150 5 speed, 2.8/4.7 SAS
My 3.4 swap http://www.yotatech.com/f160/had-officially-began-3-0-auto-3-4-manual-92-ex-cab-196823/
myyota
  • Turtle Points: -1
  • Male Posts: 120
« Reply #38 on: Jan 03, 2010, 01:05:28 PM »
That doesn`t mater, its the same alternator thats in you 86, it will bolt in and the plugs (wiring) are the same. I plan on buying one for my 86 4Runner soon.
86 4Runner
« Reply #39 on: Jan 03, 2010, 02:55:48 PM »
your thinking too hard, its much simpler than that :therethere:  it can share the same battery/batteries,  just hook the excitor wire to a switch on the dash
so dont knock it till youve done it.
cost of my dual alternator setup FREE from parts i had laying around
how much for a 150 amp alternator??  most START at $1 per amp
Quote
you'll remember when it dies in the middle of the trail
« Last Edit: Jan 03, 2010, 03:06:42 PM by 79coyotefrg »
« Reply #40 on: Jan 03, 2010, 03:06:52 PM »
no where near the same as my 79 though now is it??
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #41 on: Jan 03, 2010, 03:27:01 PM »
I like the idea of 2 alternators.
If 1 goes south, you still have 1 charging.............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
« Reply #42 on: Jan 03, 2010, 06:21:05 PM »
thats saved me twice out on the trail :yupyup:
myyota
  • Turtle Points: -1
  • Male Posts: 120
« Reply #43 on: Jan 03, 2010, 07:58:30 PM »
No, but you can always upgrade to the newer style alternator, it has a higher output and you can eliminate the external voltage regulator.
86 4Runner
gwbaker [OP]
  • Turtle Points: 2
  • Male Posts: 27
« Reply #44 on: Jan 04, 2010, 06:47:26 AM »
i still like the idea of having two alternators myself, and where the ac pump used to sit is a perfect place i could just mount it solid and use the tensioner to tighten the belt, just have to make a bracket, and just wire it up seperate of the factory system and you wouldnt have to use and isolator and just run the winch and lights off of that system, lots of options, i think it just a matter of opinion or what best suits your needs, cause any of it would work, just my two cents......
dntsdad
  • Turtle Points: 8
« Reply #45 on: Jan 04, 2010, 09:46:56 AM »
 :thumbs:
Last post May 17, 2006, 06:57:03 PM
by RustyToy
Last post Mar 18, 2007, 10:55:02 PM
by guywithuglyyota
Last post May 08, 2008, 10:08:00 PM
by topar
Last post Mar 08, 2009, 12:22:36 AM
by germ
Last post Nov 05, 2009, 11:20:00 PM
by emsvitil
