Author Topic: It ok to run 4.7 gears in a single t-case setup?  (Read 7366 times)
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
  • I'm not being rude. You're just insignificant.
i wouldnt mind having a cheap and easy way to have 2low.... def gona keep an eye out on this one
Those are some huge welds!
Tillamook, OR
2manytoys [OP]
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
It's not my original idea. I found an old post here trying to find info on my missing interlock pin.
Some guy took one shift rail from a forward shift case and one rail from a top shift case and used both stock shifters. Instead of the shifters being side by side, one is in the forward shifter location slightly in front of the stock top shift location. One shifter for each rail.
You have to remove the interlock pin just as you would for a twinstick and weld a piece of metal on the shift forks to close the open side off so the tip of your shifter doesn't fall out of position.
I think it's a great idea and I'm going to try it soon. You can see in my pics it should fit just fine.
88 Pickup SAS'd, 3.4 V6, R151F Hybrid, Dual Ultimate, Triple sticks, 35's, 5.29's, HP front, V6 rear, Aussies, 63" Chevs, Anti Wrap Bar, Warn 8274 on Home Built Bumper
4WU linked 86 Xtra Cab build in progress
Last post Jan 02, 2004, 12:01:38 PM
by 84runner
Last post Nov 23, 2004, 09:22:33 PM
by Hyena
Last post Aug 13, 2008, 08:55:24 PM
by focushere
Last post Jun 17, 2009, 04:48:26 PM
by KingofChilli82
Last post Jul 03, 2010, 04:20:26 AM
by greg_k113
