Author Topic: Lifting an '06 Raptor Key Performance Tripple Axle Toy Hauler  (Read 6788 times)
Yota87Truck
  • Male Posts: 1,175
  • Member since Aug '06
  • Got Moab!
This is my bosses trailer.  I landscape for him but often I do odds and ends for him at his shop shuch as install air bags on his F-350, swap tracks and shocks on his race sleds (Turbo M-8, and M1000), maintain machinery and now lift his huge trailer with his step dad that if you asked me is 80 years old and crawls under trucks without a creeper with less thought put to it than I do.
We also added a hitch on the rear and some big casters in case of bottoming out.  The purpose of the lift is to prevent the rear from bottoming out.  We started by marking the location of all the spring hangers.  Then we cut off the spring hangers from the frame with a torch and grinder.  We cut all brake lines and any other lines that would be streached or in our way.  Then we put 2 4"x2" square metal tubing  with 2 2"x2" cross braces in between the frame and the spring hangers and welded it to the frame and then we welded the spring hangers back on.
Yota87Truck [OP]
  • Male Posts: 1,175
  • Got Moab!
More Pics
Yota87Truck [OP]
  • Male Posts: 1,175
  • Got Moab!
After getting all the brake lines re wired and putting everything back together my boss headed to Idaho from utah.  On the way back from utah he got 3 flats.  Uppon arrival we realised that one axle was tweaked 1/8" and it was also bent affecting camber.  After fixing that problem my boss also realised that the trailer company now puts E rated tires on their current trailers of the same size so he upped the tires from D to E and has had no futher problems.
Here is the damage done from tires blowing.  I also got the pleasure of fixing the wiring and gas lines in the wheel well that got damaged.  That was fun.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Nice job.
Halladay
  • Member since May '09
  • HALLADAY
Hows she Crawl?  :gap:
axled89
  • Turtle Points: 296
  • Male Posts: 2,526
  • Member since Jan '09
lifting a trailer is awsome. :thumbs:
i love oregon wheelin.
86rustbucket
  • Turtle Points: 45
  • Member since Jun '09
i see you reinforced the bottom of the I beam with some 1x1 tube, did you put braces across parallel to the axles between those 2 x 4 pieces??
Yota87Truck [OP]
  • Male Posts: 1,175
  • Got Moab!
Actually the 1x1's were there stock, and yes we put some square tubing parallel accross to prevent /\ movements
Last post Feb 06, 2003, 04:54:28 AM
by 95TacoTruck
Last post Mar 09, 2007, 07:47:53 PM
by Tice
Last post May 30, 2009, 10:46:33 AM
by 05gixxr6
Last post Sep 01, 2009, 04:58:57 PM
by *FFC*
Last post Mar 11, 2011, 12:27:40 AM
by OVRAROK
