83 Jdm as flop build, ditched the 88
Started by mattlosch, September 20, 2009, 06:59:42 PM
mattlosch
yeah i need to get out to one..... i have the 3.0L v6.....  i will try to get to a u-pull-it today...
1983 caged, 22re, slammed
2006 cummins 6spd... somewhere around 750whp for a tow rig
mattlosch
goat pictures from today.. more tomorrow...
axled89
what elevation are you at there??
i love oregon wheelin.
mattlosch
it was 3750 but we went up higher than that
86bobbedtoy
mattlosch
i sheared off all my studs that hold the aluminum cover that holds where you lock in the hubs at.. the ones with the cone washers.. just on one side.. ... what should i do??
89sastoyo
There are a few differen't things. People have write ups on here somewhere but they were wayy wayy old so i wouldnt know how to go about finding them. But you can drill them out bigger and tap them drill out the hub to eliminate the cone washers. I wouldnt go that route my coods did he has the build on here witht he datsun and they last its just a lot of work. I would just pull the old ones out and buy new studs cones and nuts and check the aluminum part to make sure its not ovaled out then just install all new. I would put a touch of locktite on there or just check them every trip. The reason they break is because they get loose which ruins the design of the cone washer and it gets slop which alows more of a shock load towards the bolt ya know?
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
TIMS89CRAWLER
you can try an easy out too
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
89sastoyo
yeah thats what I meant when i said pull them out haha. I learned a trick to though just tack nuts to them if the easy out doesnt work and you can just pull em out easy
92 2wd DD
first gen cab
TIMS89CRAWLER
Quote from: 89sastoyo on November 22, 2009, 10:37:00 PM
yep! that also works great!
www.choptechfab.com
CHECK THE BUILD
mattlosch
i cant tac nuts on them, they are a little bit back not quiet flush.. im going to try a easyout tomorrow... might just have to order some from toyota but they wont be in till next week sometime :( so no wheeling this long weekend....sh*ty... does ifs trucks have these same things?? i know there was some ifs trucks at lkq
toyotanner
you might still be able to get it even if there not flush... maybe
its worth a try i've got some broken studs out of some messed up places lol
mattlosch
lol i will try it.. worth a shot at least.. i just need to find some studs asap.. anyone have ideas?? is a ifs set up use the same studs?
83 Crawler
im pretty sure they are.. but don't quot me on that
mattlosch
i might try to go get some at u-pull-it tomorrow.. i know they have some ifs trucks out there and i bet these are still intact...... worth a shot i gues... i want to get it out and wheeling this weekend
mattlosch
83 Crawler
 do they have any first gens? or ifs rear axles?
mattlosch
im not sure... i know there is blue ex cab with bed 3rd gen... pretty straight... i think it had a rear axle
HDcruiser
Quote from: mattlosch on November 23, 2009, 07:22:29 PM
FYI, i allways have better luck using left handed drill bits. As long as your drill has reverse the drill bits seem to work better. I bought mine off a tool truck, but i think Harbor freight should have them as well. Just an idea.
HDcruiser
I work for Frito lay as a mechanic and we allways have problems with the 5.7 exhaust manifold bolts breaking in the cylinder head. 80% of the time i can remove and broken bolt with a left hand drill bit. Good luck Bro.
83 Crawler
o sick! how much do you think they will charge for the hole thing?
Halladay
hey matt!!!
i got a new number 503-935-2853 i have had it for 2 days now so thats why i havent gotten back to you if you text or called me lol
toyotanner
i believe the ifs studs are the same
Quote from: mattlosch on November 23, 2009, 07:34:42 PM
lkq out in damaskas
2 mins from my house haha
83 Crawler
Quote from: toyotanner on November 23, 2009, 10:30:06 PM
iv been to your house once with matt but you wernt there lol
89sastoyo
ok matt don't quote me but I might have an extra hub assembly like where the studs go but ill have to look tomorrow. If not I have ifs ones with studs which will work so either way i have something. Also have extra hubs. Basically my house is lkq so hit me up 971-219-7829
92 2wd DD
first gen cab
mattlosch
i just text you adam....
i really need those studs i want to go wheeling this weekend!!! hook it up lol
and i will try those drill bits.. i bet that would work!!
mattlosch
got all me studs, cone washers and nuts tongiht!!! thanks alot man i owe ya!!!!!!!!!
cederrowe
god and I had a ARP full set of studs  I was trying to give away..............lol Glad you got your truck fixed. Those cone washers are hard to find when your in a hurry, they almost stopped one of my wheeling trips one time.
mattlosch
yeah if it happens again i will go arp's... luckly i got hooked up and its all good... ready to go wheelin now!
