Removing a spring
Started by 85 toy crawler, September 19, 2009, 05:21:32 AM
85 toy crawler
Can anyone tell me wich spring i need to remove to lower the center of gravity,the set up i have in the front is Marlins 5" spring'swould like to go down 1-2 "
crazykooter
Is this the front or the rear ?  If its the rear then dont remove a leaf, swap out with someone who has the 4" springs.  If u must remove a leaf then you need to remove one of the full length leafs.
88_Pathy
I pulled 2 leaves in the rear with All Pro 5in and need to pull 1 in front.  It is all preference though. In the rear I pulled the bottom most leave and the leaf that is right below the clamp.
85 toy crawler
these are the front springs i need to lower,i am 4-linked in the back
82juguete
not too sure on the fronts.... id be cautious about takin too much support outta those springs because you have the weight of the motor on them..wouldnt want them to bend.  I know it sucks but i would've gone with 4"ers
88_Pathy
I would pull the 2nd leaf up from the bottom.
85 toy crawler
yjay
I pulled my bottom leaf in the front (the little one that's like 8" long) . Dropped me down about 3/4" and gives better drag link to spring clearance .
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
88_Pathy
My reasoning for the second leaf was to keep a larger contact patch on the bottom of the leaf.. Don't even know if it makes a difference.
85 toy crawler
My truck is to high with the 5",the reasoning is removing a spring and letting out the air on my shocks to lower the center of gravity
88_Pathy
Air shocks with out links? In the front? Wow weird.
85 toy crawler
front has springs rear is linked
88_Pathy
