Your specs are crazy bad. What has the maintenance been like recently? Have you done a standard or indepth tune-up recently?This would all have a great change in your emissions results.
HC means unburnt fuel and usually a misfire indicator. CO is indication of how rich it is running. And in this case pig rich.. noticed your fuel mileage is probably crap right now. From your results it looks like a dead cyl either compression, ignition, fuel related. I would do a cylinder balance test and check for the rpm drop. Either by pulling a plug wire one at a time or an injector. (plugs should be ok and easier 22r/re)If you find one doesn't do much than do a leak down test after that. If you have a vacuum gauge your going to want to run check cranking vacuum and idle vacuum. idle you should 17-22in HG. i forget wtf cranking should be doing. So Cylinder balance testVacuum at idleCompression and leakdownAlso to make sure your cat is working looking for atleast a 100degree difference between inlet and outletPost all your numbers from the test and i'll give you the lambda and AFR.
I'm running an MSD 6A without any problems.I've heard that the multiple sparks can help with emissions........What gap are you running on the plugs? You can go larger with the MSD (.044)Also, some low readings with compression are due to the compression tester. The valve is a tire valve, and it takes some pressure to open them. I've had compression gauges read 25lbs low until I found a looser tire valve (hook up to your air compressor to test)
Do they not measure the o2 levels when they test in your state? If the o2 levels are high, then the cat could be your problem. What do you need to know about the o2 sensor. The grey shieled witre goes straight from the sensor to the ecm. The round 2 wire plug, usually has a cap taped on, is the o2 sensor test connector. That is it, besides the grounded shield.
when your injectors were serviced did you have the cold sart injector done as well? The cold start injector can leak. Have you opened up your AFM and moved the spring wheel? if you have moved it, move it back to sock. does the vehicle have any abnormal symptoms while driving?
have you tried jumping the test/timing connector and reading the flash codes?
Started by JonnyM Toyota Pickup/4Runner Tech 1979-95
Started by bambbrose Toyota Pickup/4Runner Tech 1979-95
Started by frumundacheeze Engine
Started by johnyreb69 Toyota Pickup/4Runner Tech 1979-95
Started by RN48 Engine
