0 Members and 8 Guests are viewing this topic.
Does it actually go away? Or just get masked by the motor?
is it lifted? are you still running the stock driveline? (if its lifted)
I bvelieve it goes away it could be masked though by the sound but then its not there when at a slow coast or when sitting at a idle. Could it be the valves or something like that? It is lifted and I am not sure if its tthe stock drivelines or not cause i bought it with the lift. I just added 1" longer shackels but if it was the driveline wouldnt it shake the truck when at higher speeds? start with a new drive line...that most likly your problem
you should still try slolyfe's method to be sure
Yea I tried that and the noise I was hearing was gone so I am sure it was the rear driveshaft. But then when driving around in 4 hi there was grinding noise comming from the front diff when i got up to road driving speed. What could that be? Everything works fine just a horrible noise but not there when crawling or under 15?
Started by johnyreb69 Engine
Started by Skinny_Pedal General 4WD Discussion
Started by ccannon222 Engine
Started by Lonestar Honcho Toyota Pickup/4Runner Tech 1979-95
Started by 85yotanh Toyota Pickup/4Runner Tech 1979-95
