White Rock
Started by MudSlinginYota, August 15, 2009, 07:44:27 PM
MudSlinginYota
i have started to build my 1st gen runner.my plans are not HUGE but fun and capable DD. there will be allot of  :headscratch: and :phone: then some of this :flamer: and if everything goes right LOTS of this :driving:.
this is what i am starting out with.
first things first.
cut off rear bumper,and step things
next i had to replace a rear wheel bearing and axle seal and do a tune up.
now we got it running fine and leaking no fluids.
1986 toyota 4runner http://board.marlincrawler.com/index.php?topic=61257.0
1997 dodge ram 4x4 (for sale)
MudSlinginYota
now time for the SAS
plans are for now.
toy axle
open 4:10
ruf
63" chevys rear
hi-steer
all necessary  parts
chevys primed and ready for black paint
my vicitim
YUMMY
Ready for the parts washer
thats better
MudSlinginYota
There is some pitting on the knuckle. Is this normal? bad? nothing to worry about???
chim
I think mine had some really light pitting..  I ran it anyway and never had an issue..
bigarms23
good start to your project
mudmaster
Quote from: chim on August 15, 2009, 09:26:50 PM
Same here. Hasn't leaked since rebuild about 4 years ago.
Time to go wheelin!
bleakhorizon
i remember seeing someone use a product, (coulda been jbweld, or fiberglass filler ie bondo) they smeared it over the pitting and then used a flapper wheel and had a nice smooth surface..... jst FYI if your worried bout it....
Quote from: junya92toy on January 03, 2013, 07:48:53 PM
Those are some huge welds!
Tillamook, OR
MudSlinginYota
i was thinking if i did anything i would probaly sand it with realy fine paper then some wet/dry. its not rough, you can tell the prev owner drove it like that
AaronB
Quote from: skipnrocks on November 08, 2011, 05:36:37 PM
MudSlinginYota
what fluids do you fill a yota axle with? i know gear oil in the middle i noticed a fill plug on the top of the outers
Mac5005
time to bring it to the house and let me start cutting.....
YJ - 4.7L-Ax15-D300(4:1)-D60/14B, lockright/spool 5.38's, 108" WB, 42" SX-2's
toyomr285
00taco
MudSlinginYota
46&2
Quote from: MudSlinginYota on August 16, 2009, 01:48:23 PM
I run 80W90 Valvoline gear oil in axle and the outters (knuckles) I run a high temp disc brake wheel bearing grease
Looks like a good start on your project.  :biggthumpup:
MudSlinginYota
Quote from: fortysixandtwo on August 17, 2009, 11:46:58 AM
thanks i was trying to make something of the sludge that was in there. how much grease? do i squirt it in that fill plug on the top?
MudSlinginYota
btw i went to my guy Chase at www.eastcoastgearsupply.com here in nc today and got together all the sas parts he had sitting in stock and overnighted the rest.
what length rear shackles do i need to run for the 63" chevys? NO DUAL SHACKLE SETUPS
89sastoyo
for the outers you pack the birfs like you would a wheel bearing atleast thats how i do it just keep rotating it and pack it then fill the inside of the ball full of grease put the knuckles on and if you are really feelin it you can pull those square plugs and pump it with a grease gun just dont get to much in there or it'll mess up your seals
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
MudSlinginYota
thats what i was thinking. thanks
MudSlinginYota
got all my parts today minus fj60 rotors, the axle back together half way. i will try and get some pics tommorow, i have been rushing so much to get it ready for the swap this weekend i have been forgetting  to take pics.
heres whats on the menu:
1980 front axle replaced seals and bearings
63" chevy springs
TG rear leaf brackets
TG front spring hanger
TG front shakles and frame tubes
TG hi-steer
TG u-bolt flip kit
TG shock hoops
stainless brake lines
i think the only things i need to get tomorrow before she goes under the knife is fj60 rotors and wheel spacers
MudSlinginYota
the axle is under the front and the chevys are out back. sitting on all 4's i have a little left then i will be testing it out on a trail   :biggthumpup: :biggthumpup: :biggthumpup: :clap2: :clap2: :clap2: :beerchug: :beerchug: :D 8)
stay tuned for pic uploads
00taco
MudSlinginYota
so the rear springs sag realy bad up front and are flat.need to be about 2" higher who has done this and can tell me what jyard springs i need or just buy a AAL for $50??
MudSlinginYota
ok finaly  getting around to posting some pics. i took as many as i could without ruining my camera with grease
the torcher begins
Plasma is nice
cut the axle and a bunch of other stuff just because... plasma is nice :gap:
:beerchug: to this
Shop supervisor Buckshot
MudSlinginYota
everything's lined up
hahaha
lots of burn action
the way its sitting right now. needs to go up at least 2" in the front
MudSlinginYota
#25
my ToDo list as of right now:
1 rear brake line
2 front leaf pack
3 bump stops
4 front shock hoops
5 gas tank skid plate
6 alignment
7 PTO drive shaft
8 fix some wheel studs i should have done during axle assembly  :hammerhead:
9 PAINT
hopefully tomorrow i will have 1,2,3,4,and 9 done and get some more pics
probally going to put it on 37s
Richmondo
Every time I see this thread title it makes me think of crack. Nice build so far.
Quote from: fortysixandtwo on August 27, 2008, 10:48:02 PMIt was just crazy to see this deer leap all suicidal style off this embankment right in front of us.
MudSlinginYota
 :gap: i smoke rocks!
i think it might change to ODgreen/black Rock here shortly
MudSlinginYota
got a good amount done today. almost everything but d-shaft,shocks (mine are too long),and front end lift
piece of 1x1 and the ifs bumpstops
it would have gone higher if i had it in the bucket right
bump stops worked as planned.. probaly going to make them a little taller
... its cause im just THAT cool :moon:
Mac5005
sweet man, good deal.  We should spray bomb it soon.  That way you can work out your color scheme exactly before we lay down the good stuff.  O and BTW.  You know how my eye was screwed up, i have a stye the size of mars in my upper eyelid, Its fricken sweet.
