Author Topic: General Dual case questions  (Read 1596 times)
toyconvert
  • Member since Jan '08
« on: Aug 15, 2009, 05:31:58 PM »
I have a 85 PU with dual cases and standard gears in both cases. Thinking about going to 4.7 in rear because I have some leaks to deal with anyway. Some tranny and some case leaks. Nothing too bad but enough to drip in the garage. I am not a mechanic but can perform most tasks if guided. Can you direct me to any links for general trans/case removal threads. I have seen the info on changing to 4.7 once the cases are out. I figue I have to replace all the seals and try to find the tranny leak as well. Thanks in advance.
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
Re: General Dual case questions
« Reply #1 on: Aug 15, 2009, 06:05:14 PM »
I like to Drive!
toyconvert [OP]
« Reply #2 on: Aug 15, 2009, 07:46:05 PM »
Thanks....saw that info and it will be helpful for the gear change. When I remove the cases do I have to drop the trans as well? I assume you support the tran and cases and remove the skid plate and drive shafts and drop the cases and the trans then separate for suspected leak in the trans?
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #3 on: Aug 15, 2009, 08:21:59 PM »
I leave the trans in and put a jack stand under it towards the rear.  :thumbs:
I like to Drive!
toyconvert [OP]
« Reply #4 on: Aug 15, 2009, 10:07:26 PM »
Thanks all.....will dive in and see what the next hurdle is.
P-DiseToy24
  • Turtle Points: -230
  • Male Posts: 868
  • Member since Aug '09
  • DDNB!
« Reply #5 on: Aug 24, 2009, 11:30:28 AM »
Its not to hard of a process you should be able to figure everything out... Good Luck
Last post Sep 25, 2004, 07:00:44 AM
by brainlessfool
Last post Oct 02, 2005, 11:06:15 PM
by FatAzzRunner
Last post May 29, 2006, 09:42:37 AM
by 86turboyota
Last post Dec 31, 2006, 01:41:29 PM
by fullthrottle
Last post Dec 09, 2008, 04:29:42 PM
by 95SAS
