Author Topic: Need engine help  (Read 1872 times)
86 4runner
  • Male Posts: 973
  • Member since Feb '05
  • SAS
Need engine help
« on: Jul 20, 2009, 04:05:21 PM »
Ok, so i rebuilt my 22re and it ran great. Changed the oil and it dumped out a little of what I now know to be gas. Originally i thought it was just some left over water from when i had it hot tanked. So it still ran great but then it started to bog out a little and if i turned it off and turned it back on it had a hard time starting. I let it sit for a couple days then drained some of the oil and it dumped out a quart of gas before any oil came out. So i figured i had a faulty injector.
Bought 4 new fuel injectors, put them in yesterday and now it runs like crap. Its missing, and has no power. Its firing on all 4 cylinders. checked the spark plugs and there all good. timing is good. compression checked it and cylinders 1,2,3 are at 175 and cylinder 4 is at 180.
I have no idea what the problem is so i could use any advise you guys have.
Thanks
86 4 Runner SAS, 37 inch Toyo M/T's, E-Locker rear, Lock Right front. 30 spline Longs, 5.29's, Dual Cases, Warn XD9000i
Joey88RUNR
  • Turtle Points: -23
  • Male Posts: 1,057
  • Member since Feb '08
Re: Need engine help
« Reply #1 on: Jul 20, 2009, 05:50:36 PM »
I would make sure all your vacuum lines are hooked up
86 4runner [OP]
  • Male Posts: 973
  • SAS
« Reply #2 on: Jul 21, 2009, 10:28:48 AM »
That was the first thing I checked. They're all hooked up
David
  • Turtle Points: 218
  • Male Posts: 263
  • Member since Jan '03
  • I love Marlin Crawler!
« Reply #3 on: Jul 21, 2009, 07:55:56 PM »
May not be relevant but, my 83 had the same problem some years ago and it turned out to be the fuel pump leaking gas into the crankcase.
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
« Reply #4 on: Jul 21, 2009, 07:58:09 PM »
Your on to something David
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Jul 21, 2009, 08:09:58 PM »
nope, sorry his problem cant be the fuel pump since its in the tank, he has a 22RE
Thanks
sounds like maybe the cold start injector is stuck open, its washing the cylinders with gas,   if you dont find the "leak"  it WILL burn the bottom end up
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #6 on: Jul 21, 2009, 08:18:38 PM »
sure its gas and not oil?
water would come out before oil would if you pulled the drain plug.... i know this from when i pressure washed my old block
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
« Reply #7 on: Jul 21, 2009, 08:26:09 PM »
You should be in bed getting ready for your big day tomorrow:)
  • Male Posts: 8,707
« Reply #8 on: Jul 21, 2009, 08:27:29 PM »
haha, big day was today :P its all good, after the feasting and liek 10 pounds i gained today, its 20:30, and im going to bed :)
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #9 on: Jul 21, 2009, 08:27:46 PM »
Make sure your getting proper ventilation through the PCV valve.
The misfireing can cause the raw gas to be pushed into the crankcase too.  Like Glen said, it will damage the motor is you don't resolve the issue.
Quote
86 4runner [OP]
  • Male Posts: 973
  • SAS
« Reply #10 on: Jul 22, 2009, 09:36:39 AM »
Thats what I checked first. I forgot to say that before, but yeah its turning off when its warm.
Its not water. Its gas for sure.
1985SR5
  • Turtle Points: 2
  • Male Posts: 105
  • Member since Jan '08
« Reply #11 on: Jul 22, 2009, 07:35:49 PM »
Is your cold start injector leaking a little? I don't know if it would make a difference, just a thought!
1985SR5
  • Turtle Points: 2
  • Male Posts: 105
« Reply #12 on: Jul 22, 2009, 07:39:19 PM »
1985SR5
  • Turtle Points: 2
  • Male Posts: 105
« Reply #13 on: Jul 22, 2009, 07:41:26 PM »
oopps sorry for the double post, and you already checked the injector
Last post Jul 25, 2003, 02:20:55 PM
by gferris5
Last post Aug 18, 2002, 09:12:26 AM
by Benge Scott
Last post Jan 15, 2004, 12:42:04 AM
by Snowtoy
Last post Dec 01, 2006, 11:26:13 AM
by spacoli
Last post Jun 01, 2015, 09:16:39 PM
by Cheesemaker
