I would make sure all your vacuum lines are hooked up
May not be relevant but, my 83 had the same problem some years ago and it turned out to be the fuel pump leaking gas into the crankcase.
Your on to something David
Ok, so i rebuilt my 22re and it ran great. Changed the oil and it dumped out a little of what I now know to be gas. Originally i thought it was just some left over water from when i had it hot tanked. So it still ran great but then it started to bog out a little and if i turned it off and turned it back on it had a hard time starting. I let it sit for a couple days then drained some of the oil and it dumped out a quart of gas before any oil came out. So i figured i had a faulty injector. Bought 4 new fuel injectors, put them in yesterday and now it runs like crap. Its missing, and has no power. Its firing on all 4 cylinders. checked the spark plugs and there all good. timing is good. compression checked it and cylinders 1,2,3 are at 175 and cylinder 4 is at 180. I have no idea what the problem is so i could use any advise you guys have.Thanks
sure its gas and not oil? water would come out before oil would if you pulled the drain plug.... i know this from when i pressure washed my old block
You should be in bed getting ready for your big day tomorrow:)
sounds like maybe the cold start injector is stuck open, its washing the cylinders with gas, if you dont find the "leak" it WILL burn the bottom end up
Started by WHITE_TRASH Engine
Started by Benge Scott Parts For Sale
Started by max Parts Wanted
Started by spacoli Toyota Pickup/4Runner Tech 1979-95
Started by BigMikeyC Engine
