i love your sig your down to a half of a maverick
but I've never had an issue with them contacting the rocks
Is this upgrade related in any way to a 5 or 6 knuckle stud or ARP knuckle stud upgrade?
most people all ready have some things that's why they also offer just the steeromg pin upgrade for 279
I fail to see how the upper steering head bearing for an 82 YZ250 ... is designed to handle more load than a stock Toyota trunion bearing.
Has anyone looked into a premium grade stock sized bearing? If so, what is it rated at?
How did you overcome the clamping force loss from using a bolt over a stud? Heard it's something like 40% loss using a bolt compared to a stud at the same torque spec.
Gaurenteed the reason Matt lost that bearing is because the bolts loosend becaues when torqued to the same spec as the factory stud it is not nearly sufficient.
So in other words, if you are right, then the dirt bike's headset components are INDEED stronger than Toyota knuckle bearings. As crazy as it sounds, you'd better believe it! Perhaps that is why Yamaha's are so expensive! Gotta love Japanese quality!!
it wasn't from loose bolts trust me on that one. I always make sure all the knuckle bolts are tight, I periodically check on the trail, since i have seen so many people sheer them once they even remotely get loose.
you check your lower kingpin bolts. . . . i know everyone checks their highsteer arms, but ive never seen anyone check the lower bolts. either way, bolts are NOT the way to go on anything that, under the possibility of them loosening, could cause catasrophy.
I see the failure in the design being that the taper on the bearing could be a little too much.....time will tell. As for the bolt vs stud debate it's not about the breaking force, it's about how much, and in what ways the blot/stud stetches.....which it will not matter what. When. Bolt is torqued down it you have to create a fairly significant twisting force on it to get the threads to engage, so when it stretches it not only stretches along it's vertical axis it will also twist the head causing it to loosen. A stud that is propertly installed will only stretch along the vertical axis because the force used to tighten the stud is not a twisting force.
you said it yourself... bolts should not be in this appand its Matt, not mathreal professional
THIS IS NOT PBB!!!!!!!!!!!!
Started by bhigdon101 Project Research and Build-Ups
Started by boggerunner Project Research and Build-Ups
Started by awhotrods Toyota Pickup/4Runner Tech 1979-95
Started by jl93221 Toyota Pickup/4Runner Tech 1979-95
Started by superyota Axle/Differential/Steering
