dana 44 steering knuckle upgrade question(found reamer)26.5 degree's
Started by bhigdon101, January 16, 2009, 06:15:13 PM
bhigdon101
i want to upgrade to the 9/16 studs for the dana 44
i have read all the post and searched all the threads here and on the P forum too..
so i know i can do it.. no problem.. but the problem is the taper on the hi-steer arms
i dont know what degree that is.. or how to get a special tool to counter sink them..
any info on the tapered holes in the arms will help out alot....
thanks....  brian higdon....
thanks for all the help guy's  ,, and here is a link to the reamer if you want to do it your self..
me and a couple buddy's will chip in and buy this to keep the cost down....
http://www.pscmotorsports.com/xku9000-265-degree-taper-reamer-p-501.html
daddy always said "if your going to be stupid, you better be tough"
boggerunner
keep the stocks, and add a 5th stud or here is one with the dana44 studs
bhigdon101
#2
yea i have seen the pics before, i have researched this for weeks,
and i am going to do a 5th stud too. but it will be the 9/16 stud
i need the degree of the taper on the dana 44 cone washer and
how to get taper my arms myself,
what are the dimension's of the cone washer.. length, width at top, width at bottom
then i can do the math and find the angle so i can try to find something to contersink
the arms with....
does anyone have a dana cone washer that they can mic. for me....
thanks...
                          brian higdon.....
bhigdon101
anyone know the taper on the dana 44 cone washers??
boggerunner
bhigdon101
Quote from: boggerunner on January 17, 2009, 10:22:47 PM
just go buy one from napa and measure it
that is a good idea,,
does anyone have the part #of the dana 44 cone washer from napa??
