Author Topic: Marlin 25mm Pin upgrade with 6 stud arms  (Read 13396 times)
awhotrods
  • Turtle Points: 154
  • Male Posts: 1,203
  • Member since Nov '04
« on: Feb 22, 2011, 12:18:49 PM »
Looking at getting some extra strength out of my knuckles/steering arms, has anyone installed the HD pin upgrade in 6 stud knuckles yet?
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Marlin 25mm Pin upgrade with 6 stud arms
« Reply #1 on: Feb 22, 2011, 10:09:36 PM »
If they are TG arms, they will have to be reamed out for the pins to fit. If you are one of the lucky people like me and have a set of billet arms that Marlin made, plug and play. You notice I said reamed instead of drilled because reaming is more accurate then drilling.
awhotrods [OP]
  • Male Posts: 1,203
« Reply #2 on: Feb 23, 2011, 12:44:12 PM »
Pretty sure I have TG forged arms, came with the truck.  I didn't know Marlin had a billet version, that would be sweet!!
OOPS
  • Male Posts: 2,561
« Reply #3 on: Feb 23, 2011, 04:13:18 PM »
Marlin made them when the six stud knuckles were first being designed by Marlin and Chris. When Chris bailed and went to TG he said the design was all his own and took it with him. Instead of fighting about it Marlin just let it go. There are very few sets of the Marlins out there, I just happened to get a set when I broke one of Marlins arms and he replaced them for me since they also would work on stock knuckles.
awhotrods [OP]
  • Male Posts: 1,203
« Reply #4 on: Feb 23, 2011, 07:23:34 PM »
Makes sense, after you own a 6 stud arms, stock parts look like toys.. lol  I'm upgrading to ARP studs too, should be nice & strong.
awhotrods [OP]
  • Male Posts: 1,203
« Reply #5 on: Apr 29, 2011, 12:40:57 PM »
Just got off the phone with Atteberry, according to him no one has done this mod yet, successfully...  People are just reaming the arms out by hand & having alignment issues with arms/knuckles/etc.  Has anyone done this & have trail time on the parts?  Really want to do this mod, with 4D's, wheel spacers, etc it would give me some peace of mind.  :willynilly:
OOPS
  • Male Posts: 2,561
« Reply #6 on: Apr 30, 2011, 09:10:53 AM »
Instead of having the holes in the arms made bigger you could have the pins machined down to fit. But IMO that would defeat the purpose and make them weaker. I broke a pin out of the arm and it was one inch. Myself I would have the holes in the arms made bigger. remember it is an interference fit.
awhotrods [OP]
  • Male Posts: 1,203
« Reply #7 on: Apr 30, 2011, 11:34:21 AM »
I definitely want to machine the arms, not the pins.  Does anyone know how much "interference" is required to keep the pin tight in the arm?  Do the OD of the pin & the ID of the hole in the arm have to be exact?
OOPS
  • Male Posts: 2,561
joeshmoe196
  • Member since Aug '09
« Reply #9 on: May 02, 2011, 12:34:20 AM »
.002-.003" should do. Best way to make sure  reaming it perfectly in the middle you need a bridgepprt or similar mill and take a drill bit or gauge pin that fits very snug in the hole of the arm and put it in the chuck then move the handle down and align the bore gauge or drill bit in the arm and snug up the vise the arm is in  and make sure the table of the miill doesn't move at all. Drill it out close to the size u need then find a reamer of the correct size and ream it
« Last Edit: May 02, 2011, 12:42:35 AM by joeshmoe196 »
awhotrods [OP]
  • Male Posts: 1,203
« Reply #10 on: May 02, 2011, 08:50:15 AM »
Google is the  :pokinit:
Thanks for sharing.
Goggle is amazing.
http://www.maelabs.ucsd.edu/mae_guides/Tolerance/Tolerancing.htm
 :beerchug:
joeshmoe196
« Reply #11 on: May 02, 2011, 10:12:17 AM »
Just make sure to use a sharp reamer and use slow drill speed and plenty of cutting oil let us know how it works
awhotrods [OP]
  • Male Posts: 1,203
« Reply #12 on: May 02, 2011, 06:31:20 PM »
Will do.  Ordering the kit in a few days..
Bobby Hunter
  • Turtle Points: 53
  • Male Posts: 206
  • Member since Sep '09
  • Bobby Hunter
« Reply #13 on: May 03, 2011, 10:44:23 PM »
or you could go 4x4 labs 6studs on stock knuckles
Tech head for 2nd gen Runners
joeshmoe196
« Reply #14 on: May 04, 2011, 11:31:40 PM »
Why would he do that?
Bobby Hunter
  • Turtle Points: 53
  • Male Posts: 206
  • Bobby Hunter
« Reply #15 on: May 05, 2011, 05:26:45 PM »
cause TG sucks LOL  :cheese:
OOPS
  • Male Posts: 2,561
« Reply #16 on: May 05, 2011, 05:50:25 PM »
He is talking about making your own 6-stud knuckles with 4x4 Labs parts.
http://www.4x4labs.com/products/steering/6-stud-knuckle-conversion-blocks/
joeshmoe196
« Reply #17 on: May 05, 2011, 06:51:22 PM »
I know what he was saying but it still wouldn't solve the OP problem
Bobby Hunter
  • Turtle Points: 53
  • Male Posts: 206
  • Bobby Hunter
« Reply #18 on: May 06, 2011, 10:02:00 AM »
well the 4x4 labs arms are press pin and billet vs tg cast arms so slightly easier
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
« Reply #19 on: May 06, 2011, 10:08:42 AM »
cast arms vs. welding billet to a cast knuckle?  i think the cast arm would be stronger.  i can't see welding to the knuckle being very strong, if not weakening it and causing stress from the heat.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
OOPS
  • Male Posts: 2,561
« Reply #20 on: May 08, 2011, 04:22:24 PM »
If welded correctly it will be fine.
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Drinking me beer
« Reply #21 on: May 08, 2011, 07:17:44 PM »
Cast steel or billet steel welding is still just welding steel. Cast can have porosity in it, billet wont. Now welding cast iron is very hard without proper procedures. On a steering arm, Id preheat very even, post heat, and let it cool very slow.
- Sales Employee -
freds40
  • Turtle Points: 293
  • Male Posts: 2,331
  • Member since Dec '02
« Reply #22 on: May 12, 2011, 01:19:51 PM »
Sorry I've missed this one apparently. We have put 25mm pins into the 6 stud arms both TGs and 4X4 Labs. If you purchase the pin kit and send us the arms, we'll bore the arms for you at no charge. Just pay shipping both ways.  :thumbs:
"between projects"
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #23 on: May 12, 2011, 02:54:47 PM »
wow! can't beat that.  good to know.
ABD Motorsports
#4475
KK6QDW
dweinberg01
  • Turtle Points: 122
  • Member since Jan '07
« Reply #24 on: May 12, 2011, 02:58:29 PM »
Just out of curiosity, what are some opinions on the longfield kit. http://www.longfieldsuperaxles.com/products/5TH-STUD-HIGH-STEER-TRUNION-BOLT-SETUP.html
Worth looking in to or stay away from? Sorry to hijack.
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #25 on: May 13, 2011, 12:16:35 AM »
Indeed, they even bored my old arms to fit the new pins, when I broke one, for FREE
Bobby Hunter
  • Turtle Points: 53
  • Male Posts: 206
  • Bobby Hunter
« Reply #26 on: May 13, 2011, 09:56:28 PM »
I know alot of guys that run it and love it they say it helps
yotaneck13
  • Mr. Right NOW
  • Turtle Points: -52
  • Male Posts: 2,300
  • Member since Nov '09
  • MR. RIGHT NOW
« Reply #27 on: May 13, 2011, 10:23:30 PM »
  :clap2:  :clap:  :bowdown: NOT to many shops out there with that kind of customer service.  That is why i will always choose marlin when possible. :thumbs:
Last post Nov 12, 2005, 06:44:53 AM
by h0nke
Last post Dec 30, 2010, 04:58:20 PM
by boggerunner
Last post Feb 08, 2011, 02:22:06 PM
by zippo
Last post Nov 14, 2010, 04:02:28 PM
by OOPS
Last post Nov 25, 2013, 08:50:19 AM
by superyota
