5th stud knuckle upgrade
Started by boggerunner, January 24, 2009, 05:53:37 PM
boggerunner
here is some more tech.  im working on making some 5th stud steering arms.
i got some 1/2" plate from the local scrap yard for $0.50.   i went to my buddy shop and he cut it out into 4 pieces.
then i ground them clean, and ground the top of the knuckle flat.
ive got one all welded up. i still need to drill the 5th hole and im going to weld the head of the 5/8" bolt on the inside of the knuckle.
boggerunner
and the rest. i will finish these up tomorrow
bhigdon101
will the head of the bolt hit the birfield ??
can someone show pic's of the clearance between the birfield and the knuckle??
i have a front end but have not tore it apart yet...
waiting on more parts....
i am going to do the 5 stud's but i will use the dana 44 stud's they are 9/16 fine thread..
then i will drill out by stud holes for the lockouts to 7/16 fine thread for some bob long
drive flanges and drill some 5/16 dowel pins (6 of them)
thanks brian higdon...
daddy always said "if your going to be stupid, you better be tough"
boggerunner
there is a pocket for the bolt to fit in, hold on a few and i will go snap a pic
boggerunner
i got a pic and i also measured the clearence, and there is more than 3/4" for the head of the bolt.  the head of the bolt will be right between the 2 dimples.
boggerunner
got the drivers side finished up today. i used a grade 8 1/2" fine thread bolt with a locknut for the 5th stud.  on to the pics.
I will get these finished tomorrow and get them on the truck.  i will need to clearence the head of the bolt a little.
Wermz84
Nice looking welds.  keep it up.
I like to Drive!
yota_krawler
thats bad ass. I had been thinking about doing this, I sheered 3 studs off about 3 months ago. looks good
boggerunner
its a cheap mod too, ive got about 3 hrs time and $2.50 in bolts and $0.50 in steel.
i will eventually swap the 4 studs out to arp ones, but this will keep me from breaking them in the meantime.  i also left a gap between the new piece and the knuckle for shims like the top.
TIMS89CRAWLER
I like the way you did this one.... I am gonna do something like this when I get my new studs and longfields... nice work  :thumbs:
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
toyotanner
i think this is a neat idea. is the stud welded in the knuckle? from the pics it either looks welded or you put some sort of sealer in there... just wondering because if its welded hopefully the stud never strips out
95SAS
damn thats, easy. Great job! let us know how it holds up
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
boggerunner
its welded, dont know how im gonna strip it out, i shouldnt have to pull these arms off anymore after this.
Tool Pimp
Looks sweet wanna do mine next  :eyebrow:
boggerunner
sure, ship them with some beer
Tool Pimp
boggerunner
here are some more pics of the other side.
and got everything painted.
boggerunner
ive also got to replace the trunion bearings
boggerunner
i got them installed and shimmed.  they turned out good.
Pariah
Nice job! Great alternative to six shooters.
ElkoToy
Great to see write ups on thing I can do.
axled89
i love oregon wheelin.
hi on lux
boggerunner: how are these holding?
boggerunner
they were holding up great, but i sold them and parted out the truck they were on, they wont work with front range offroads taco brake kit cause u have to swap the pass and driver side knuckles
