Halladay.. 88sastoy..
Started by Halladay, June 17, 2009, 11:07:14 PM
0 Members and 6 Guests are viewing this topic.
Halladay
i only grounded down the booger welds and fliped the cage over and welded the spots were he didnt. the welds were not bad the penintrated but they didnt look good.
Halladay
Ok so here are pics of the progress i got today...
-grounded down some welds on the cage welded over some, painted the cage
-tour apart my top shif case for my duals and welded diff armor on the rear axel
-cut off the front bumper so the cage can go on
-wired wheeled the crawl boxed and got her shinny
ok look at the last picture of the t case and tell me how to get this gear out? its pi**ing me off
this pic right above this is the gear i need to get out. how do i get it out? yes i took the snap ring out and the tension pins holding the shift rail on.. do i just beat the hell out of it?
Halladay
from the out put side or the toward the gears right?
GhostMoney
take a rubber mallet so you dont damage output and hit the end of the output shaft, should pop right off. When I did my gears I had to do the same
toyotanner
use a press or in some cases i've got it out with a hammer
Halladay
ok cool im going to try and get that out today and bolt the addapter plate to the crawl box. then im ordering my clutch and rear main as well as cutting my fenders to match my cage. ill let you guys know if i get it out
Halladay
just got done cutting the fenders it looks alright... it will look alot better with the cage on. i cut them to match the bottom tube on the cage so they are going to overlap then i painted the whole inner fender.
potter85
 have been thnking about cutting my fenders like this for a while but still havent done it... still up in the air about it... looks good
3rz in the making
looking for 38s
2 tundra 4.7l v8 soon to be sas'ed
Halladay
now that i have done it... dont cut the stock body line running up the truck(the one running flush with the door. i have like 2 inchs from the door to the out side of the fender. give yourself about 5 and it will look alot better. my is going to be covered with the cage so i dont care lol
Halladay
got the cage set on and going to tack the rear in place and take my truck to bufallo welding and my buddy has a hydrolic bended there and we are going to re bend the tube going to the front of the sliders. here is some pics of the cage with the hack job fenders....
the cage makes it top heavy when im maxing it out. once the tire starts to pick up it really trys to go over lol
Halladay
just picked up my frontrage offroad x-member/skidplate combo.
the only problem im seeing is my stock t case mont dont bolt up to the skid plate does the skid plate just work as a solid mount? i think it does but im just making sure. any one running the x-members?
GrenadedToy
http://frontrangeoffroadfab.com/nfoscomm/catalog/product_info.php?cPath=21&products_id=30&osCsid=50be8fe540b413a6f0deadfeb9a3c1d1
"The Front Range Off-Road Fabrication Skidplate, can only be installed once the Crossmember is installed. It bolts onto the existing holes in the transfer case, where the factory rubber mount was originally bolted"
83 Crawler
your truck has come along sence i first saw it!  :thumbs: now i need to get off my lazy as and start getting parts for mine  :gap:
Halladay
duals are in. but the x-member is not welded in yet. i have two problems my front case is shifting fine and noww my rear case will not shift. i cut the rails but i guess i have to cut more... or what else could it be? and heres a pic of my second problem... with my flat belly and duals it puts my out put shaft about 3 inchs from gas tank x-member. what can i do here? i have seen ppl just cut it out and i have seen ppl weld a hoop to it. but my case is pushed up so much it wont fit anything above the flange. i have maybe 3 inchs. i need advise! thanks guys
junya92toy
my 3.0l idles too high after a drive on the freeway when its good and hot. I have no clue
pumkin toy
heres a pic of what i did on mine.  i know the pic isnt that great but you can see what i had to do for driveline clearance.
97 4runner Limited
GrenadedToy
Just an Idea and More work than Im sure you want to do But its only made out of 3 pieces of 2x3
Dont forget to route your brake/fuel lines.
Halladay
Got the duals in and now im waiting on Driveline Tech to build my driveline. Marlin MC07 R10 adapter, marlin HD 1200 lb clutch,Frontrage Offroad X-member skidplate combo here are some pics of the build and my last wheeling trip with a stock single case.
Wheelin was a short notice kind of thing and i had no one to help me remove it. and i had it on cause i was messureing bends and bending them at a good old buddy Curtis lewis's house hahaha. si yea i had to leave it straped on. not proud of it but it held and didnt move at all......
luvyota
lol you do what have to to go play. and i like your build up good job   :thumbs: i should make a thread on mine.
luvyota
Halladay
haha for sure. its nice cause i got the truck bone stock and did everything my way  :beerchug:
Halladay
wait you have a chevy luv!?!?! those are so sick haha post some pics on here im trying to see it! my buddy had a luv and wanted to run a yota running gear on it. Lets see some pics!!!
hilux-1983
Quote from: luvyota on July 27, 2009, 12:59:06 PM
Lets see it, nice avatar
luvyota
here it is before i took it apart
luvyota
luvyota
this is it now but it is a lil diffrent with bigger tires and other stuff. i cant get the other ones to load they are to big  :mad: i will try to get some more up
luvyota
hilux-1983
You might wanna start your own thread though. Nice so far.
Halladay
that is pretty cool. i have never seen a built  4WD Luv.
luvyota
thanks guys when i can when i find all the pics i will make my own thread
luvyota
