Halladay.. 88sastoy..
Started by Halladay, June 17, 2009, 11:07:14 PM
Halladay
Quote from: 86rustbucket on September 10, 2009, 11:18:14 PM
.what kind of bushing did you replace it with?
poly bushings. you can buy them through a auto parts store. i bought mine through robs offroad
GrenadedToy
I used front chevy leaf spring bushings that were poly from baxters for my body mounts. Probably use them for the same thing.
Halladay
Well its time to rebuild my front nuckles. i have some bad caster camber going on and my tires are wearing funny and my nuckle is leaking gear oil. so inner seal is toast.... i hope... haha im also having problems with my front breaks. there still solid rotors and they are heating up soooo bad to the point where they burn the :pokinit: out of you if you touch them.
Things on Order
-Tie Rod ends
       to fix my steering. mine are striped out were the castle nut goes on.
-Nuckle Rebuild kit
-Trail Gear Rock Rings.
-Cone washer
       Missing one.... found that out when i did my ARP's
I also got around to mixing my front springs.... i took the overload out of the front and got a set of 2wd toyota rears. mixed all 3 (not the overload) into my pack and it gained 3 inchs of lift and i acually gained flex from it. idk how haha ill post pics 2marrow.
GrenadedToy
Quote from: Halladay on September 17, 2009, 05:11:14 PM
Im workin on it i have to go buy batterys for my cammera
Rechargables BRO! lol i have 5 sets of AA's
Halladay
Here you guys go...
mixed my front springs and got 3 inchs or more of lift and gained flex and here are a couple pics of my extended shifters
those u bolts are tight too by the way.... still gotta build some clamps
extended 3 inchs with a 3 inch poop pipe nipple from the local hardware store
Brandon505
well im probably gonna take my body lift off now :\ how bout some side pics?
Halladay
Quote from: Brandon505 on September 17, 2009, 09:15:32 PM
i will get some its dark now and my cammera sucks so i will 2marrow. why you taking your body lift off?
Brandon505
make it lower. im on 33's 4 inch suspension with a 3 inch body.
Halladay
Quote from: Brandon505 on September 17, 2009, 09:41:07 PM
yea thats legit. i built mine around it so im leaving it. but your in the spot were you have to loose one way of lift and body has to go. haha
Brandon505
toyotanner
i'm not a fan of that tacoma grille on the 2nd gen it might be alright if you had the headlights to go with it... you should see if ryan still has that square headlight taco grille
Halladay
Quote from: toyotanner on September 17, 2009, 10:20:04 PM
i dont like it that much the way it is but is better than my thrashed 2nd gen grill  i could always do a taco front clip!
86rustbucket
i think it looks sweet with that grill, never seen that done before
swapped89
Black hood and new grille look sic! we gotta go wheelin soon....You work tomoro?
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
Halladay
Quote from: swapped89 on September 18, 2009, 11:55:35 AM
thanks man... and yea i do... i have sunday monday off but i have to rebuild my nuckles cause they are leaking like a siv
Halladay
Quote from: 86rustbucket on September 18, 2009, 11:33:35 AM
thanks man
89sastoyo
tannner i have that grill you silly
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
swapped89
i was on timbercraawler and saw this. thought you guys would think its funny. http://twitter.com/shitmydadsays go to this link and read the :pokinit: this guys dad says.
swapped89
ah crap it dont work cause of the bad words in it. i'll send it to ya on myspace. lol  or if ya just replace the :pokinit: picture with the word it will work
Halladay
Quote from: swapped89 on September 18, 2009, 09:50:28 PM
its not workin send it to me over the space bra lol
swapped89
mattlosch
next time you guys go wheeling and should let me know i would love to tag along
1983 caged, 22re, slammed
2006 cummins 6spd... somewhere around 750whp for a tow rig
axled89
#177
nice light's  looks good.   :suprised:
i love oregon wheelin.
Halladay
Quote from: mattlosch on September 21, 2009, 05:15:03 PM
ok for sure you live by browns right?
89sastoyo
92 2wd DD
first gen cab
