Halladay.. 88sastoy..
Started by Halladay, June 17, 2009, 11:07:14 PM
NorCalToy
mine still does it with the set screw turned allll the way in. so goodluck. :thumbs:
:flamer: IFS
Halladay
just got my mc007 dual addapter with the 10 degree clock! but it didnt come with the shifter knob!!!
Halladay
ok so most of you know im about to start my duals and flat belly. whats the best way to flat belly my rig? (remember it has a three in body lift) i ordered the front rage offroad crossmember and skid plate combo and going to lift the tranny and t-cases that way but then my motor is at a angle. anyone heard of extended motor mounts?  :headscratch: or know of anyone making them?
Halladay
got the front locked up now with birf eliminators. picked them up for 300 with the super joints
toyotanner
if you go flatbelly you have to raise the motor if you plan on driving it on the road otherwise your tcases will chatter
Halladay
HERE IS THE LINK TO THE EXO I BOUGHT TONIGHT i was there when he cut it off so its all legit i will have pics of it on my truck 2marrow let me know what you think!
http://portland.craigslist.org/mlt/pts/1252441948.html
toyota_smasher
I looked at that first picture of your truck on the build a couple times and found out that i have seen that truck before at the bottom of the hill thats my property right behind it lol Nice truck by the way
Runner- sas,locked front/rear,5.29s,dual cases,30 spline Longfeilds,36in swampers on beadlocks,Much more
GrenadedToy
Thats a cool cage setup but it would be cooler if you built your own. :twocents:
Halladay
really lol thats were my build started at my uncles house off holcomb blvd. thats were i didall my motor work now i do everything at my place. you got a build up
Halladay
ya i know but for 200 bucks i couldnt pass it up. i would have spent more in tubing... let alone a bender, wire, gas, and time lol
toyota_smasher
no i dont i was going to start one a while back but never did i have pics of it on my myspace if you want to see it. Do you live in oregon city? i havent seen the truck sense it left the backyard lol
Halladay
yea send me a link.... and no i live outside gladsone off riveroad
toyota_smasher
http://www.myspace.com/justinrebholz I found your myspace off one of my friends and i sent you a friend request
Halladay
Here is pictures of the cage set on my truck. i still need to cut off my old bumper and cut my fenders to match the bottom tube on it. What do you guys think? paid 200. i know it would have been cooler if i made it myself but i would have been into it that much in tubing. let alone wire and gas for my welder. and a tubeing bender or i should say kinker
hilux-1983
hilux-1983
You said it best on post #48. I agree!
Halladay
thanks man. good investment in my eyes. its a first for me seeing a exo caged dd let alone driving one haha :beerchug:
Halladay
im going to lower the front of the cage down a couple inchs as well as tuck the rear closer to the cab. im going to grind down the guys welds that i bought it from and re-weld it cause he ARC welded the whole cage lol
LilChief87
Halladay
for sure i got some pics im going to put up in a little bit. i grinded all the welds and re did them and painted it
LilChief87
when you gettin it all the way mounted and done  :disturbed:
GrenadedToy
Quote from: Halladay on July 10, 2009, 10:27:29 PM
I really dont think you need to do this. Those welds arent bad and from what I remember Arc welders get better penetration than MIG.
Dingman.
It depends if the welder knew what they were doing.
If the welds are good i wouldn't worry about it.
Whats the ratchet strap for?
GrenadedToy
Quote from: Dingman. on July 12, 2009, 06:12:09 PM
Ive seen a lot worse and they arent bad welds. I just think it might be a waste of time to grind every weld down and reweld em up.
Ratchet strap was holding it down.
