With no noise w/d-shaft out, and quieter w/new u-joints back in, I would say it has to be something in the rear axle. Could be the pinion bearing, could also be axle bearings and the noise is traveling tup the d-line and being amplified by the transmission.Before tearing into the third, put the rear up on stands and see if you can hear the noise. Or get an automotive stethoscope and listen to the pinion as you have someone else spin the tire.
New u-joint did not solve the problem. It's quieter now, but not gone. So I guess I'm looking at...pinion bearing (both t-case and rear diff?) and what else? Wouldn't be brakes or anything since I didn't hear it in front wheel drive, right?
Started by TigerToy Engine
Started by whitetoy General 4WD Discussion
Started by Jared88 Toyota Pickup/4Runner Tech 1979-95
Started by Old Man from FL Newbie Questions
Started by xnoahx Transfer Case/Drive Line
