Author Topic: Driveline noise  (Read 2914 times)
TigerToy
  • Turtle Points: 77
  • Member since Apr '04
Driveline noise
« on: Apr 26, 2004, 01:20:13 PM »
Ok, Something is making a grinding noise when coasting at higher rpms in fourth and fifth gear.  I'm pretty sure that its not my transmission (I just got a new one from Marlin), and I saw on another post that it could be my pinion bearing.  It does kinda sound like a bearing noise and I do have a bit of a driveline vibration.  There isn't a whole lot of play in the bearing though, so I was wondering if it could be something else.  Its not really irritating, so I might just wait until it gets worse or breaks, then I will know for sure what is wrong with it.  Any suggestions would be appreciated.  I've already done the whole jack it up run it with the tires off the ground thing, and the noise seemed like it was gone or at least a whole lot quieter.
TigerToy [OP]
  • Turtle Points: 77
Re: Driveline noise
« Reply #1 on: Apr 26, 2004, 01:21:26 PM »
Another reason why I was thinking it might not be the pinion bearing is that it seems to go with engine rpm and not speed.
hawaii500_1999
  • Turtle Points: -7
  • Member since Jun '02
  • Watch this!!!!!
Re: Driveline noise
« Reply #2 on: Apr 26, 2004, 01:58:13 PM »
is either the pinoin flange or the "T" case flange loose?
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
yotaboy79
  • stuck in the shop
  • Turtle Points: -19
  • Male Posts: 2,838
  • Member since Aug '03
Re: Driveline noise
« Reply #3 on: Apr 26, 2004, 03:35:02 PM »
did u put a new piolit bearing in when u replased the tranny that could be makin noise
TigerToy [OP]
  • Turtle Points: 77
Re: Driveline noise
« Reply #4 on: Apr 26, 2004, 06:40:25 PM »
Yes, I replaced it, but bad pilot bearings don't make noise when the truck is in gear because they are not turning.
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
Re: Driveline noise
« Reply #5 on: Apr 26, 2004, 09:09:53 PM »
I don;t know about the grinding noise but i have mad vibrations after installing my dual cases in 3,4 and 5th gears.  May just be my rear driveshaft.
Prismo
  • Online The 1K Club
  • Turtle Points: 8403
  • Member since Oct '03
  • Living in the green house
Re: Driveline noise
« Reply #6 on: Apr 26, 2004, 11:49:24 PM »
You need to put a CV on that rear driveline or change your pinion angle more than likely
yotaboy79
  • stuck in the shop
  • Male Posts: 2,838
Re: Driveline noise
« Reply #7 on: Apr 27, 2004, 06:23:35 PM »
i never thaught about the the piolet bearing not turning oh well i tryed to help :-\
TigerToy [OP]
  • Turtle Points: 77
Re: Driveline noise
« Reply #8 on: Apr 27, 2004, 06:35:12 PM »
NP, thanks anyway.  :beer:  Honestly, I took my driveshaft out and there was no play in the pinion or the transfer case flange.  So, no dice there.  I'm beginning to think that its just my clutch fork vibrating at a certain rpm, because its got some play in it and it makes noise at idle.  So, I don't think its a really big deal.  I actually had a problem kinda like this before with a mustang that had a wore out clutch fork.
yotaboy79
  • stuck in the shop
  • Male Posts: 2,838
Re: Driveline noise
« Reply #9 on: Apr 27, 2004, 07:07:32 PM »
run it till it drops :yupyup:
Last post Mar 04, 2009, 06:46:34 PM
by pumkin toy
Last post Oct 20, 2009, 11:58:59 AM
by 83MT
Last post Apr 20, 2011, 07:32:49 PM
by Jared88
Last post Apr 28, 2015, 12:53:53 PM
by Rocksurfer
Last post May 05, 2017, 07:51:29 PM
by xnoahx
