Anyone have a crack in there engine block and actually fix it without replacing the engine? I've got a small crack on the middle drivers side of my 22RE engine block. Its been there for 8yrs or so now and as long as I keep some stop leak in the coolant it only ever seeps on occasion. However I know that over time it can only get worse and in a couple weeks I'm going on a long road trip to colorado and back with the girlfriend. My worry is that the seep will turn into a drip and then......
I talked with my old boss a long time ago and he suggested I use a technique called "pinning". You find the ends of the crack, drill a hole, tap it for a pipe thread plug, grind head of plug flush with block and repeat, slowly working your way to the center of the crack. Seems like it would work and It'd probably only take a few 1/8" pipe plugs to fix my crack. However, I'm leery of drilling into my engine block and creating more issues right before a big trip. Anyone ever done this?
Any other ways to fix a crack in an engine block? I know enough to not even try welding it and no, JB weld doesn't seem to work.
Thanks,
Kevo
