93 IFS Curb Crawler
Started by JanMarie13, April 28, 2009, 06:14:58 AM
sounds like the timing was off and bent all 4 exhaust valves
Quoteit spins freely til it hits a little hard spot...
that sounds about par for a set of bent exhaust valves
simple to diagnose, back adjustment off on all valves and see if it rotates any different
twistedtoy92
yotaneck13
uu need a new motor bro mines holdn strong jushit 6k yesterday not problems except the elusive vac leak i have and ive beat her pretty hard in them 6k bring me the pats ill build u a bullet proof re
PA_taco_13
Quote from: 79coyotefrg on September 20, 2010, 04:30:16 PM
yep definitely jumped time.  the truck is leaking around the intake valves.... :sick: :thud:
i knew i shoulda got a new motor  :maddest:
learn the hard way
"my dixie wrecked"
east coast crawler
Quote from: PA_taco_13 on September 23, 2010, 07:41:16 AM
just replace the bent valves,   was this engine just rebuilt??  if it was just replace the bent valves,  if not then you should have the head rebuilt
PA_taco_13
can anyone help me with a bolt question. i need to get stock body mount or cab mount bolts for my truck. I'm going to install a energy suspension body mount kit <urethane stock hight> and want to know what bolts to get before i get to the project.
found this on yotatech:  yeah, they're metric 10 mm diameter x 80 mm long with 1.25 threads per mm.
80 mm is about 3.5 inches
  :dunno:  is this right for a 93 extended cab truck? I think the guy was commenting on 4runner bolts
learn the hard way
"my dixie wrecked"
east coast crawler
yota4x4sc
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
Brian, 80mm is really close.  I might have some that are in good shape. theynever seen any snow :cheese:  I'll look tomorrow.
PA_taco_13
 :thumbs:  sweet glenn!. let me know what ya got and how much.  :king:
learn the hard way
"my dixie wrecked"
east coast crawler
Quote from: PA_taco_13 on November 25, 2010, 07:12:31 PM
send me a pm tomorrow and remind me cause I forgot to check today :(
JanMarie13
Ummm......   words or something?   I was instructed to post these pics:    :cheese:
:psss:  It's still on the trailer cuz it needs to be aligned before we can drive it anywhere.  It's getting aligned on Wednesday.
RIP Kyle, we love and miss you man.  :smooch:
Quote from: KYOTA on October 03, 2009, 10:33:31 AM
thanks for the smooch I miss you too !  :yesnod:
IronClad
Annihilation  Fabrication
Do you need a Hammer?
wakkjobb
I was gonna say I missed living back east until I saw the rust  :yikes:
Any word on another engine or repair or whatever?
PA_taco_13
#136
Red red knock'em dead. I had a bunch of stuff just layin around collecting rust it seemed, so I painted it all. I found a little can of red caliper paint in the shed so I put it to use. calipers, rear drums, lift parts and the diff.
I wish i could drive the truck but it needs aligned
new stuff= engine, poly bushings front to back,poly bump stops, superlift 4", sr5 oil pressure sender, torsion adjust bolts, eccentric bolts caster/ camber, 4 ball joints
slightly used stuff= 5.29's front and rear, lower arms right and left, sr5 gauge cluster
needs= upper bump stops installed, cab mount bushings installed, bushings, shackles n shocks for the rear.
learn the hard way
"my dixie wrecked"
east coast crawler
PA_taco_13
Quote from: wakkjobb on November 28, 2010, 06:13:29 PM
I'm gonna do my best to take care of that rust  :hammer:
learn the hard way
"my dixie wrecked"
east coast crawler
Quote from: PA_taco_13 on November 28, 2010, 06:22:34 PM
strip it to a bare frame and POR15 that pregnant dog!
unclejpl4x4
you know bri if U ever wanna just give up  you can drop it in my driveway
PA_taco_13
learn the hard way
"my dixie wrecked"
east coast crawler
JanMarie13
Quote from: PA_taco_13 on December 02, 2010, 06:23:16 AM
:king: got my rig back! :thumbs:
:hyper:   Which means I got my 4Runner back!!!    :love:
JanMarie13
#143
Behold....2 new pictures for your viewing pleasure.
EDIT:  :psss:  Apparently this was not simply for viewing pleasure.  I just realized these pics are from two different days, and the purpose is to compare wheels.  Do we like the black wheels in the top pic, or the other ones in the bottom pic?  Oorrr the simulated beadlocks from earlier in the thread?
unclejpl4x4
GJToyotabug
ya know i see a bunch of trucks that have a lift like that and for some reason it doesnt look like their that much higher than mine and i dont have hardly any lift.
i vote black for sho!
46&2
PA_taco_13
Quote from: GJToyotabug on December 23, 2010, 03:20:59 PM
funny you should say that. my truck is a giant mess right now. the first pic ( passenger side with the blk taco wheels ) the front is lifted with a 4" super lift and the rear is a 2" add a leaf 265/75/r16 tires.  the rear needs to come up another 2 to 3 inches. you can"t really tell in the pic it looks like i have about 700 lbs in the bed to see the truck in real life. the second pic ( driver side 5 star alumies ) cranked downey torsion bars and same 2" add a leaf 31x10.5 r15
learn the hard way
"my dixie wrecked"
east coast crawler
GJToyotabug
give me a call sometime i can build a 3 leaf add a leaf kit that eleminates the overload and ive been hearing about 3inches of lift with just the kit. or new springs! :gap:
PA_taco_13
learn the hard way
"my dixie wrecked"
east coast crawler
