Author Topic: IFS Hub to Solid Axle Hub Conversion  (Read 6263 times)
  • Turtle Points: 1174
  • Male Posts: 5,057
  • Crawlin with Marlin
« on: Apr 07, 2009, 06:39:12 PM »
I recently upgraded my Solid Axle Hubs with Longfield Hub Gears.  Are the hub gears that Bobby sells the same for IFS or different?  I'm interested to know if the old hub gears from the solid axle hub can be used to covert IFS hubs or if the gears have more differences than 27 vs. 30 splines.
 :dunno:
I have the old hub gears and kept them mostly because I thought someone might be able to use them to convert a set of IFS hubs are seem to be more available than the solid axle variety.
John Doe
  • Turtle Points: 469
  • Male Posts: 1,587
  • Member since Jun '05
    • Bored In Iraq.
Re: IFS Hub to Solid Axle Hub Conversion
« Reply #1 on: Apr 07, 2009, 06:59:40 PM »
I dont see why you cant use your old hub gears to convert the ifs hubs. Should work  :dunno:
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #2 on: Apr 07, 2009, 08:02:32 PM »
they will work in ifs hubs, the only difference is the spline count in the 79-85 to 86-95 hubs
ifs are 27 and sfa are 30 i think
« Last Edit: Apr 07, 2009, 11:30:22 PM by boggerunner »
Birfailed
  • Turtle Points: 14
  • Member since Sep '06
  • Stand on it!
« Reply #3 on: Apr 07, 2009, 11:27:07 PM »
Hey, my hubs are 35 spline...wtf?
Go 1-Ton from the start
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #4 on: Apr 08, 2009, 11:35:43 AM »
 :dunno:
Heights are different.  putting SA hub gear into IFS hub body won't allow that outter c-clip to fit.  (This is from web reading..)  (or the heights of the hub bodies are different..)
Bobby's IFS hub gear are different than the SA hub gear.  (stated on his site.)
Closest I could find.
http://pirate4x4.com/forum/showthread.php?t=749835&highlight=hub+gears
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #5 on: Apr 08, 2009, 02:20:22 PM »
really, cause i just got his sfa hub gears and put them into ifs hubs, and they worked great today, and went together perfect.
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Annihilation Fabrication
« Reply #6 on: Apr 08, 2009, 02:44:12 PM »
bogger all you had to do was read this part...
Do you need a Hammer?
Jordan7118
  • Turtle Points: -21
  • Male Posts: 1,105
« Reply #7 on: Apr 10, 2009, 02:41:17 AM »
Read what you want.
http://www.pirate4x4.com/forum/showthread.php?p=5979707
Only thing I know is that I got IFS-to-SFA conversion gears from Bobby Long to use in my IFS hub bodies.
Birfailed
  • Turtle Points: 14
  • Stand on it!
« Reply #8 on: Apr 10, 2009, 03:06:45 AM »
lol cased close  :shake:
Jordan7118
  • Male Posts: 1,105
« Reply #9 on: Apr 10, 2009, 03:31:01 AM »
Then what's the answer, Birfailed? You haven't contributed anything  :smack:
If they're the same, then why would Bobby make an IFS conversion hub gear? That makes no sense...
This shows that IFS hubs and SFA hubs are different.
http://www.pirate4x4.com/forum/showpost.php?p=5957430&postcount=7
Birfailed
  • Turtle Points: 14
  • Stand on it!
« Reply #10 on: Apr 10, 2009, 04:15:16 AM »
call bobby 360-893-0235
SloCrawler
  • Turtle Points: -116
  • Male Posts: 1,333
  • Member since Mar '08
    • http://board.marlincrawler.com/index.php?topic=60800.msg856812#msg856812
« Reply #11 on: Feb 20, 2010, 09:12:15 PM »
So an ifs hub would match up to an 79-85 axle?  Use the ifs brakes and rutor and offset the calapirs and you gain 2.5" in width. Correct?
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #12 on: Feb 21, 2010, 07:36:13 AM »
u gain 3" to match the 86+ rear axles
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
« Reply #13 on: Feb 21, 2010, 07:46:58 AM »
you gain 2 1/2"
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
« Reply #14 on: Feb 21, 2010, 07:50:55 AM »
no, you need fj rotors. thats not what this threads about anyways. this is about the lockout hub dial.
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
  • Member since Oct '09
« Reply #15 on: Feb 21, 2010, 07:59:07 AM »
I have an IFS lockout with SFA parts in it and I CANNOT get the outer c-clip on the axle this is from first hand experience not web reading.  Again why would bobby make a conversion if they were the same?
Jordan7118
  • Male Posts: 1,105
« Reply #16 on: Feb 24, 2010, 03:35:53 PM »
There ya have it, folks!
Last post Jun 11, 2004, 02:31:16 PM
by SWAMPER
Last post Jan 15, 2015, 09:28:25 PM
by Rocksurfer
Last post Aug 04, 2021, 06:58:33 AM
by zidaro
Last post Jul 17, 2022, 08:47:10 PM
by 83_P/U_4x4
Last post Aug 01, 2023, 08:13:31 AM
by OVRAROK
