I recently upgraded my Solid Axle Hubs with Longfield Hub Gears. Are the hub gears that Bobby sells the same for IFS or different? I'm interested to know if the old hub gears from the solid axle hub can be used to covert IFS hubs or if the gears have more differences than 27 vs. 30 splines. I have the old hub gears and kept them mostly because I thought someone might be able to use them to convert a set of IFS hubs are seem to be more available than the solid axle variety.
(This is from web reading..)
lol cased close
u gain 3" to match the 86+ rear axles
So an ifs hub would match up to an 79-85 axle? Use the ifs brakes and rutor and offset the calapirs and you gain 2.5" in width. Correct?
Again why would bobby make a conversion if they were the same?
Started by SWAMPER Engine
Started by firemanpig New Member Check-In!
Started by dntsdad Parts Wanted
Started by area560 Newbie Questions
Started by memorybox New Member Check-In!
