The Jackstand! new meats..
Started by skipnrocks, March 19, 2009, 10:10:46 AM
skipnrocks
thanks yeller...
Now on my list I just have
Swap new radiator
taurus fan
sliders
bumpers
stinger
belly up
ect......
WILLYNILLY
skipnrocks
Well I got some work done today and i really went well for winging it....
Got the radiator flushed, and it was bad it had 1/4in of lime scale build up on the top of the rad core...
got the radiator out, 7 years of leaves packed between the ac coller and radiator, and cut out the stock fan...
and got the new radiator in with the new taurus fan, and one of the things made me super happy is I got the radiator overflow mounted back in the stock location by building a new bracket to hold it..
I also found some power steering ideal operating temperatures and found that I should be running around 210 and since thats what my motor runs at I found I could use the tranny cooler as my hydro steering cooler and cleaned up things even more, got rid of some hose and overall I am super stoked,, left on my list is...
the jeep is much quieter now its a pretty cool mod
finnish panhard bracket
front bumper
rear bumper
sliders
and belly up t-case...
then wheel it for the rest of the year and start a new list for next year....
WILLYNILLY
Broke_Okie_Ty
nice work on those fenders. im not usually a fan of Jeeps but yours is looking good  :thumbs:
skipnrocks
WILLYNILLY
skipnrocks
well it took about 5 hours but I got my jeep apart and back togetherI now have just below 17in of belly clearance which is just an inch lower than when I had my lift (but now my frame height is only 18 in which it was just over 22 before)  , my skid plate is 1in down from the frame gaining me almost 3in.  I actually had it up high enough to flat belly it completly but my rear driveshaft will bind too soon if I push it up any more unless I get a hp ford nine in the rear...
WILLYNILLY
GJToyotabug
skipnrocks
i plan on it but it will be after i get a job...  LOL
I left for school this morning and heard this horrible metal clunk repeated, and i though oh crap its my cv binding but as I sped up it went away and then the next start up same thing,  so i get out to check things out and there is a brick my little boy put in the rim and the bead lock rim was keeping it in....  Funny kids... LOL scared the piss out of me..
now left on my list is
sliders and bumpers
shes getting close to being done...
WILLYNILLY
*** YELLER ***
Quote from: skipnrocks on June 08, 2009, 06:57:04 AM
So let me get this straght after you herd the noise you speed up :rofl:  :slap:
:usa: :beerwhack:
except BACON
skipnrocks
WILLYNILLY
skipnrocks
got a present in the mail yesterday!  Im stoked!!   its going to be great for the trails, I have to make some twin sticks for it and this fall I will put a 4:1 kit...  But for now it has upgraded front and rear shafts and a cutting/e-brake
WILLYNILLY
GJToyotabug
sweet dude nice to see this thing isnt gonna be just like every other jeep :thumbs:
skipnrocks
Thanks man,  I have put alot of thought into the best setup, not just the newest accessory... I like how its looking..
WILLYNILLY
GJToyotabug
are you using stock link bars or whats up their?
*** YELLER ***
except BACON
hilux-1983
skipnrocks
Quote from: GJToyotabug on June 25, 2009, 05:55:10 PM
Im using lengthened stock for now, and this fall I will be getting a shipment of heims and start building my new link arms...
thanks yella and hilux im super excited especially with all the tight trails around here...
I picked up the flat stock and some sweet 1 off shifter nobs for the twin sticks...  its going to be those little hand ratchets facing in opposite dirrections... so when your shifting 4hi and 4 low it will be like a normal shifter and opperate as a unit then the little nobs will be easy to deal with to shift individual... not sure if that makes sence but I will take pics when I start working on it...
WILLYNILLY
skipnrocks
Well I had a little change of plans,I was going to plate the rear door and then reinforce the factory hinges then throw my tire on there, well I wasnt sure if it would work but the plate would have been 40 extra lbs on the door...  So then I came across this tire carrier and it was everything I needed, it opens and shuts with the rear door, no extra latches or anything, its hinges bolt through the body to some 1/4in brackest that attach it to the roll cage and frame so there is no stress on the body!  I couldnt be happier, got it all put together last night and modded it for my backspacing..  Now I just need to weld on some tabs for my high lift and I will be one step closer to be ready for wheelin!
WILLYNILLY
Bazzi
skipnrocks
WILLYNILLY
skipnrocks
Well spent a few hours and built the front and rear bumpers...  I still need to weld the d-rings on and weld in the reciever to the rear bumper, and decided how to reinforce the loop up front, but I got all the main stuff cut and welded...  I forgot to take pics of the rear bumper but its not much to look at yet without the reciever or d-rings...
WILLYNILLY
*** YELLER ***
tie it into the fenders :dunno: or to the top of the frame under the grill :dunno:
except BACON
skipnrocks
cant do the top of the frame next to the grill since I will have the factory sway bar there for the time being..  I like the idea of going to the fenders but only if I can make it removable....  it would suck to have to remove the bumpers and fenders as one unit...
WILLYNILLY
Bazzi
is that the brick in the pick .... rear left rim ;)
*** YELLER ***
#84
Quote from: skipnrocks on June 30, 2009, 05:52:24 PM
drill hole in the fender tube...
weld a nut inside the stinger tubes...
bolt them together   :smack:  :sly:
like this  :greengrin:
My photoshop skills are awesome
:usa: :beerwhack:
except BACON
skipnrocks
Quote from: Bazzi on June 30, 2009, 06:08:25 PM
Yep that was courtacy of my little boy!  thought I had something blowing to pieces when I pulled out with that in there...
WILLYNILLY
skipnrocks
Yeller your photoshop skills do rock!!  LOL  I like the idea but maybe not winging out so far, but I think I am going to try and talk the wife into something like that...
WILLYNILLY
skipnrocks
alright got to spend a few hours putting some dimention to my front bumper...  heres the final look.. I still need to do a few things like cap the ends and gusset the outer corners then paint and bolt on...  Im pretty happy with how it looks, it gives a finnished look to the front that I havent had almost since I bought it...
WILLYNILLY
skipnrocks
sorry yeller your photoshop skills wernt good enoughto talk the wife into going back to the fenders and she didnt like how I wanted to keep the sides of the bumper square with frame so she had me put these sides on  and that gave a convenient place to run back to with some tubing...
WILLYNILLY
skipnrocks
Heres the final pics oft he front bumper..  I still have to trim the bolts that run through the bumper but its not going anywhere, its held on by 8 grade 8 bolts..  I used a textured paint so that the new steel on tubing would look more like the textured plate i used...
WILLYNILLY
