Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
0 Members and 48 Guests are viewing this topic.
 :down:  okay boys and girls  should i just throw another 20R in there and have it running or start pulling it apart for the real deal, punch that block to 94mm,  have another 20 head totally ported with monster valves,  send the tranny and tcase to marlin and maybe a set of downey 3" springs front and rear,  oh did i mention the clean 84 front axle i found for $100
Skinny_Pedal
go balls the wall. marlin has 3" springs to u know
Im an OG
Quote from: 86runner on September 26, 2004, 05:33:32 PM
Marlin has springs?? :dunno:
brainlessfool
 GO FOR IT!
I popped my 22R out to 94mm. got the pistons from LC. forged.  kinda pricey butt good pistons.
and put in bigger exh. vavles too. what the heck go for it!
Quote from: brainlessfool on September 26, 2004, 05:36:10 PM
 GO FOR IT!
how much did those extra 2mm help
brainlessfool
i meant the 94mm pistons over the stock,     if i go big valves i think i'll go 48mm intake and 40mm exhaust with a 1 5/8"header :flamer:
hmm just checked the LC catalogue,  maybe just stage 3 head,  :yupyup:
Skinny_Pedal
Im an OG
brainlessfool
ok, if I have the hibreed motor thing right. the main benafit is raised comp. Y/N ? if it is your be better off (I think) going with a 22R head and bigger valves in it. the LC pistons gave me about 10:1 C/R
and thats planty. nice cam and your in! I think a motor like that will out run a hibreed motor on the low end and the top too!   my  :twocents:
brainlessfool
with the 94mm pistons my motors now 2.5 cc
the storker crank was like   $1800.00 ouch! not for me!
20R heads are super cheap,  but i see what your saying,  already have the LC stage 2 cam ready to go
guess i need to spruce up the celica a little since i'll be in it till the beast is revived  :ladys-man:
Skinny_Pedal
sorry to budge in but if i put in 94mm pistons that makes my motor a 2.5......this i like. o did i tell u guys i may be getting a 2.6 though :yupyup:. back to glens motor now
Im an OG
brainlessfool
Quote from: brainlessfool on September 26, 2004, 05:50:27 PM
with the 94mm pistons my motors now 2.5 cc. I bet 86 will say the same thing like he's the frist one to do so! just watch.
I knew it!
#16
How much do you plan on spending? You could probabely convert it to EFI, slap in an entire 22R-E with harness and all sensors and ecu for under $1000 you know, in good runing condition too.
Stock I bet the 22R-E will take your :bling: pumped up 20R for a ride. You could eaisly build a 20R that will tear the doors off a stock 22R-E, but I doubt by much, and the larger displacement of the 22R engine will yield better bottom end torque for rock crawling and also the fuel injection will get better gas mileage..
Then you could do all the fun stuff like the header, air filter, cams, plugs and wires, etc..
just my :twocents:
Mike D
I have an efi that i would sell
87 runner, 4" trailmaster lift, 33" TSL/SX, 5.29's V6 e-locker, 22re that cost too much
kyle_22r
if i test drove a stock 22R powered rig, and a stock 20R powered rig with the same amount of miles and engine condition, i wouldn't really be able to tell the difference.  the 22R does have a bit more torque, but i think the 20R is even more indestructable.  something about the thrust bearings being superior, and the fact that it was never available with a single row timing chain or plastic guides
Mike D
 they now have aftermarket steel timing chain guides for the 22re's
i have my eye on a 85 with efi22 with a rod hanging out of the side of it,  beds mangled but its got a good tranny and tcase,   if i buy this truck its going SUPRA MOTOR
but old Blue,    im staying with a weber,  thinking,  a 38 weber, 94mm block, ported 20 head and big valvesi can get my block bored for less than $75,  already have a crank at the speed shop getting the works
hey Mike,  do you know anything about . technotoytuning.com ??  he has eibach adjustables for my celica for $179
blyota91
So I take it boring to 94mm is as big as one can go in a 22re?  What size over bore is this?  I was planning to do a .040 overbore in mine, just cause I can, but is the 94mm bigger.  I'd figure it out on my own but I don't know what the stock bore is.
Retiring the 91
Rebuilding the 94
brainlessfool
I do belive that 94 MM is as big as you SOULD go on a 22r/re
Quote from: blyota91 on September 29, 2004, 06:54:59 PM
94mm is .080 over
blyota91
Are pistons for .080 over easy to find?  I would love to buy some LC high compressions pistons, but they're just a bit too spendy for me.
Retiring the 91
Rebuilding the 94
Thumper
Dont buy LC crap THEY SUCK, there pistons are JUNK :_oops: my friend spent like 2500 on crap from lc he had the 94 mm big bore kit the adjustable timeing kit cam bigger valves 30 lb flywheel centerforce clutch and all that other crap they sell and them damn motor dident last but right at 50,000 miles before a piston came appart so he calls up lc they said ohh ya we have been haveing problems with that happening we dont know why they do that,they said they have had lots of people call in and complain about that problem, but wont do anything about it or even tell u this before you buy the kit, they wouldent do crap about replaceing the motor and just said well sorry thats ur problem pretty much so i think they are a bunch of cheating A$$ holes that there products suck and are not worth buying.
Well thats my  :twocents:
sorry if i barged in on ur thread but i just wanted you too know before you buy.
If it was me i would just bore it out too 40 over and have your 20r head shaved down and ur pistions clearenced so the valves dont hit them and run your bigger valves and your cam with the weber and header and you will be amazed, and if your thinking about up gradeing too a 38 check out the 45 mm side draft kit and friend of myne bought a truck the other day that was sittin in a field and it had the sidedraft carbs this thing was only hitting on 3 cylinders and it would still roast the 35's off with 4.10 gears threw 2nd it was amazing, those carbs are way worth buying if you can afford them.
Good luck whatever you decide
adam :beerchug:
If you didn't make it, and it ain't broke, you didn't try hard enough.
um  last i checks side drafts were like $1500,  :rivers:  when i win the lottery i guess
 :down:  well its been 2 weeks and i sooooo miss my truck  :dunno:  so im going to pick up a 20R from BillChase friday and have it running by saturday,   He also had some oversize pistons i think im going to buy also,  i just have to have my truck,  this was i can send my block off for boring and have fun at the same time, :driving:
brainlessfool
Hey
glen
can't you just find a cheap 22r to though in while you do up you dream motor?
And here ya big baby, have a point!  :laugh:
well i found a celica with a 22 efi  but  it was froze up  :headshake:
20's are cheap and plentiful around here
thanks for the point,    whos a baby  :coffee:
