ok i know this is a dumb question but im not sure if it will work? can you run rears up front with stock steering on an 81? i have done a ball flip and i have an extended drag link. will i have any problems? or do i need to get histeer?
My 4runner has rears up front and stock steering until I can find a ifs box. It wont work with the spring pin in the center hole, you have to use the front hole on the drivers side perch and drill out the pass side to match.
Moves your axle about 1 1/8 forward on the front notch. Either turn the pittman arm a notch or deal with your steering wheel being upside down.
Started by TigerToy Project Research and Build-Ups
Started by dende Engine
Started by dat82toy General 4WD Discussion
Started by KYOTA Rig Gallery
Started by yota-tota Engine
