Author Topic: rears up front questions?  (Read 4604 times)
punchyyoter85
  • Turtle Points: 31
  • Male Posts: 171
  • Member since Sep '07
« on: Mar 04, 2009, 03:17:16 PM »
ok i know this is a dumb question but im not sure if it will work? can you run rears up front with stock steering on an 81? i have done a ball flip and i have an extended drag link. will i have any problems? or do i need to get histeer? :dunno:
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
  • Member since Jul '07
  • drive it till it breaks! then break out the tools.
Re: rears up front questions?
« Reply #1 on: Mar 04, 2009, 03:25:24 PM »
Going from stock fronts to rears up front, your axle will move forward (2", I believe). This means that you will have to shorten the drag link or move the steering box forward to match.
SAVE TELLICO post 491
peacesells
  • Turtle Points: -17
  • Male Posts: 791
  • Member since Jul '08
  • motley lou
« Reply #2 on: Mar 04, 2009, 03:29:08 PM »
My 4runner has rears up front and stock steering until I can find a ifs box. It wont work with the spring pin in the center hole, you have to use the front hole on the drivers side perch and drill out the pass side to match. Moves your axle about 1 1/8 forward on the front notch. Either turn the pittman arm a notch or deal with your steering wheel being upside down.
this my man lysol, fresh out the joint
punchyyoter85 [OP]
  • Turtle Points: 31
  • Male Posts: 171
« Reply #3 on: Mar 04, 2009, 03:32:27 PM »
so pritty much its not worth doing with stock steering?
peacesells
  • Male Posts: 791
  • motley lou
« Reply #4 on: Mar 04, 2009, 04:04:08 PM »
if you ask me, yes. Not worth wheelin with stock steering.. Even with a drop draglink youll start breaking j arms.
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
« Reply #5 on: Mar 04, 2009, 04:05:42 PM »
If you are trying to upgrade the front suspension and keep the truck driveable, yes, it would be worth doing. To swap to hi-steer, you would need the steering box, pump and lines, as well as the hi-steer kit. The above mods will allow the stock steering to operate properly until you get the parts to replace the steering.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #6 on: Mar 04, 2009, 05:42:04 PM »
this is very simple really,  it can work BUT you have to shorten the drag link as much as the rears move the axle forward,  its that simple
then remove the torque rod and install an old shock in its place
instant flexy
:headscratch:  what kinda dang axle are you using :headscratch:
Quote
you can easily pull the steering wheel and re center it :thumbs:
punchyyoter85 [OP]
  • Turtle Points: 31
  • Male Posts: 171
« Reply #7 on: Mar 05, 2009, 03:02:11 PM »
yeah im just wanting to upgrade from stock untill i can get some money for histeer. how much would you have to shorten the drag link?  :dunno: would it be sqirlly? because i had a truck before with the axle moved forward with downey springs and i could only go like 35mph down the wighway.? and the drag link way was shorter than stock.
dniel
  • Male Posts: 194
  • Member since Feb '09
« Reply #8 on: Mar 07, 2009, 11:32:46 AM »
I would wait till you get your highsteer. This way you can set every thing up at the same time and make sure it all works together. Highsteer clearance is usually the limiting factor on up travel so it is nice to have it installed when you set up your suspension.
The only thing I know about push pull steering is how to remove it so I can't offer a lot of advice there. When people are talking about shortening the drag link I'm assuming they mean cutting and re-welding it. If you are going to do this I would recommend having it welded by a professional. If you do it yourself sleeve it. I have a nice miller welder and consider myself pretty skilled but I would not be confident welding steering components.   :nerv:
1uz-fe, 1 tons, 44" tsl
punchyyoter85 [OP]
  • Turtle Points: 31
  • Male Posts: 171
« Reply #9 on: Mar 07, 2009, 12:05:27 PM »
yeah i just got done ordering highsteer! so im going with that. thanks guys for you help! :beerchug:
Sleeve of Wizzard
  • Turtle Points: -1
  • Male Posts: 293
  • It's craptaculer
« Reply #10 on: Mar 07, 2009, 03:15:35 PM »
I did it with a adjustable drag link and a flipped j arm ball. So far no problems from those.
85runner_
  • Turtle Points: 2
  • Male Posts: 204
  • Member since Dec '07
« Reply #11 on: Mar 15, 2009, 09:02:38 PM »
Same here. Shortened a drop drag to work.
Now highsteer and that jury rig is gone..
« Reply #12 on: Jul 16, 2009, 02:04:32 PM »
you do NOT put the entire un modified rear pack in the front like this pic
not sure what the guy was thinking but DONT DO IT,  it will provide NO lift at all and the diving boards up front just look STUPID
Halladay
  • Member since May '09
  • HALLADAY
« Reply #13 on: Jul 27, 2009, 08:39:49 AM »
  :shake:
studentwheeler
  • Turtle Points: 121
  • Male Posts: 382
  • Member since Feb '06
« Reply #14 on: Jul 27, 2009, 10:37:48 PM »
I run rears up front with stock steering. I just drilled new holes 2 inches forward of the stock holes on the spring perches to compensate for the off center center pin on the rear springs. They wheel great and ride great on the road. I run a dropped drag link. No breakage but i carry a spare j-arm just in case.
punchyyoter85 [OP]
  • Turtle Points: 31
  • Male Posts: 171
« Reply #15 on: Nov 23, 2010, 04:56:52 PM »
so its been along time since i posted back but since i totaled that truck and working on another, so i can do this with a j ball flip and adjustible drag link? i have both of those, and what do i have to do with the leaf packs? dose anyone have picks?
Last post May 21, 2004, 01:40:39 AM
by GRM
Last post Nov 14, 2004, 03:42:34 AM
by WHITE_TRASH
Last post Jul 02, 2009, 05:32:54 PM
by 86rustbucket
Last post Nov 28, 2005, 07:54:58 PM
by KYOTA
Last post Aug 17, 2006, 07:26:26 PM
by AlaskaToy
