Author Topic: intermitent tach  (Read 1713 times)
llamas
  • Male Posts: 142
  • Member since Sep '08
intermitent tach
« on: Feb 18, 2009, 07:24:53 PM »
on my 80 ...the tach will work about 5% of the time ..sometimes i'll start the engine and it'll be fine for 10mins and then quit and won't work again for a week then i'll be driving along and notice it will be working again ... i checked the obvious at the distributor itis fine , iv'e messaged all the wires going thru the fire wall and under the dash but i can't reach the tach.i have not messed with the dashboard ever .. seems odd that it would be so intermitent..  any suggestions are welcome
             thanks you for ANY help :driving:
don whitman
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
Re: intermitent tach
« Reply #1 on: Feb 18, 2009, 07:38:17 PM »
clean all the contacts at the coil, make sure ALL engine related grounds are good. good luck
83MT
  • Turtle Points: -23
  • Member since Jun '08
« Reply #2 on: Feb 19, 2009, 07:25:49 AM »
Pull the cluster if nothing else checks out. Super easy on these trucks. 5 screws to get the cover from around the cluster, then 4 screws on the cluster and it's out. Could be the wire is loose or bad connection at the back of the panel. Does it look like somebody ran a new wire for the tach, or does it look like it was wired for it from the factory?
Zach
I like Yotatech
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #3 on: Feb 19, 2009, 07:58:37 AM »
Cable could be broken too and just sometimes *catches just right* to spin the cable enought to get the tach moving for a second..
Lol.  This would be a speedo cable.  Not tack.   Sorry.    :D
Last post Sep 22, 2004, 07:01:18 AM
by SWAMPER
Last post Dec 12, 2004, 07:58:53 AM
by toyoder
Last post Dec 13, 2004, 10:45:20 PM
by Marlin
Last post Sep 10, 2005, 04:13:01 PM
by Weldo
Last post Jul 31, 2006, 03:21:08 PM
by RockSlayer
