Author Topic: I need help with a 91' 4.3L tach installation.  (Read 5421 times)
RockSlayer
  • Turtle Points: 176
  • Male Posts: 101
  • Member since Jan '06
  • A mind is a terrible thing to taste.
    • Cal4wheelers
« on: Jul 25, 2006, 12:13:05 PM »
I bought my son a 1991 S-10 that we will eventually turn into a 4x4 crawler. It has a 4.3 with TBI. We were installing one of those big 5" tachs with a shift light, and I was wondering if anybody knows if there is a factory tach connector somewhere in the mess of wires? There is not a tach in the dash from the factory.
Ferg
  • Turtle Points: 416
  • Male Posts: 577
  • Member since May '03
  • That was EASY!!
Re: I need help with a 91' 4.3L tach installation.
« Reply #1 on: Jul 26, 2006, 09:21:51 AM »
Check at the local library.  You can look at wiring diagrams for free.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Jul 26, 2006, 09:56:52 AM »
on the distributor  there  is a plug  on the side,  should be 1 thats empty, its for the tach
RockSlayer [OP]
  • Male Posts: 101
    • Cal4wheelers
« Reply #3 on: Jul 26, 2006, 10:12:50 AM »
That is where I was looking, just like on the HEI distributors, but this has the coil on the right side valve cover. No tach connection there either.
Thanks for the idea, I forgot about the library. I'll give that a try.
« Reply #4 on: Jul 26, 2006, 11:15:01 AM »
hmm,  this has the muti coils??    all you need is 1 connection to 1 primary wire to 1 coil
RockSlayer [OP]
  • Male Posts: 101
    • Cal4wheelers
« Reply #5 on: Jul 26, 2006, 04:49:13 PM »
It looks like one coil, It's just mounted by the valve cover and has a coil wire that goes to the center connector on the Distributor cap, just like in the old days. It has 2 plugs going to it, both with a red and a white wire on each plug. the wire gauge is different for the 2 plugs. I'm going to poke around today after work. I'll see if I can just go old school and hook it up to the hot side of the coil. I was hoping for an easy / clean connection.
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
« Reply #6 on: Jul 26, 2006, 05:24:59 PM »
Wish I could help. I used a Howell harness when I did my conversion and it had a wire stubbed out for for the tach and i'm not sure if their color would match the factory.
I checked my service manual for you, but couldn't find anything referancing the tach. Sorry.
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • Member since Feb '05
  • I named my son Wheeler!!!!
« Reply #7 on: Jul 26, 2006, 09:19:24 PM »
It just so happens that I have a Haynes manual for a S-10, but......it does not mention anywhere in the whole book where to hook up a tach!!! Even the wire diagram of the instrument cluster doesn't have a factory tach. It does talk about hooking up a hand held tach for idle control on a carbed engine, but says to follow the manufacture's (tach) recomm :therethere:endation on where to hook it up. Sorry!
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
RockSlayer [OP]
  • Male Posts: 101
    • Cal4wheelers
« Reply #8 on: Jul 27, 2006, 07:35:14 AM »
I was thinking, maybe it is better I don't hook it up. He might think that 4.3 with 223,000 miles can turn 10,000 rpms. :gap:
FIREBALL
« Reply #9 on: Jul 27, 2006, 08:16:43 AM »
The rev limiter will keep him from doin that.
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
And what do you think the rev limiter sees, RPM. There should be a connection at the brain for the tach. you need to get the manual for that year and search for it. I had no problem hooking mine up on a 93 4.3.
I suffer from CRS so I can't help with the details.
RockSlayer [OP]
  • Male Posts: 101
    • Cal4wheelers
i went old school with this tach install. I hooked it to the negative side of the coil. Foo-ee on the ecm signal crappolla. It works great. i set the shift light to 4500, and told him if he blows it, we can't rebuild it.  :hammerhead:
Last post Sep 22, 2004, 07:01:18 AM
by SWAMPER
Last post Dec 12, 2004, 07:58:53 AM
by toyoder
Last post Dec 13, 2004, 10:45:20 PM
by Marlin
Last post Sep 10, 2005, 04:13:01 PM
by Weldo
Last post Sep 01, 2006, 05:38:58 PM
by Lonestar Honcho
