Author Topic: turn check engine light off??  (Read 5865 times)
4x4Haze
  • Turtle Points: 7
  • Male Posts: 337
  • Member since Feb '07
« on: Feb 03, 2009, 01:34:23 PM »
i recently rebuilt my 3.0 and it keeps throwing out various codes but after i fix them it dosent turn off, can i reset it or turn it off??
A jumper cable walks into a bar. The bartender says, "I'll serve you, but dont start anything."
  • Turtle Points: 2872
  • Male Posts: 8,707
Re: turn check engine light off??
« Reply #1 on: Feb 03, 2009, 01:40:20 PM »
disconnect the negative battery cable, put key in ignition and hold in start position for 20 seconds, remove key, wait 30 minutes, then reconnect negative battery terminal
should have all the codes cleared out....
4x4Haze [OP]
  • Turtle Points: 7
  • Male Posts: 337
« Reply #2 on: Feb 03, 2009, 04:48:22 PM »
thanks! it worked
Homefries
  • Male Posts: 241
  • Member since Apr '07
« Reply #3 on: Feb 04, 2009, 10:26:45 PM »
Or turn the ignition off and take out the EFI fuse under the dash and wait 30 sec.  Disconnecting the battery cables is not necessary and is not recommended.
80_yota_pickup
  • Male Posts: 86
  • Member since Dec '08
« Reply #4 on: Feb 05, 2009, 01:05:48 AM »
if you have an autozone near your location they will clear the code out for free.
cause if you disconnect the battery sometimes it will throw the same codes over again cause it completely resets the comp.
SAY i WON't... AND i WILL
80 pickup SB with 87 4runner SR5 interior,22re swap, welded F&R, 5" allpro springs, ultimate duals, 36" iroks, DIY beadlocks,SB bobbed 16",
coming next: full cage, longfields, and 5.29's
4x4Haze [OP]
  • Turtle Points: 7
  • Male Posts: 337
« Reply #5 on: Feb 06, 2009, 10:11:08 PM »
well my light came on again after about 100 miles or so, i gotta check it out again. but the first time it was sayin i had a bad cylinder but i just had the thing rebuilt and it runs better than ever
  • Male Posts: 8,707
« Reply #6 on: Feb 06, 2009, 10:14:32 PM »
autozones in CA will not check your codes for free, nor do any of the auto parts stores rent out or loan their scanners anymore.....
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • F***in catalina wine mixer
« Reply #7 on: Feb 07, 2009, 12:40:24 AM »
put a sticker over it! best way to get rid of a check engine light haha
UA 342
STEAMFITTERS
80_yota_pickup
  • Male Posts: 86
« Reply #8 on: Feb 10, 2009, 01:02:00 AM »
i agree all the way or just cut the check engine light wire and call it a day!
that sucks about the scanner up here in oregon they will just run out and do it for you.
  • Male Posts: 8,707
« Reply #9 on: Feb 10, 2009, 01:37:52 AM »
as far as cutting the wire, they check for that too when they test it.... it the light doesnt come on in the start position then go out, they assume tampering and fail it....
you could rig up something on its own circuit to time delay it maybe only once as soon as its started.... but......
usually it's better just to fix it, instead of mask the problem
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #10 on: Feb 10, 2009, 11:38:43 AM »
:dunno:  I'd check anyway.  They do in Vacaville and Sacramento.
              -Ronald Reagan
Loosekannon
  • Turtle Points: -26
  • Male Posts: 1,301
  • SoCal--ROCKBRAWLERS--
« Reply #11 on: Feb 10, 2009, 07:56:03 PM »
So did you find out the code and get it fixed??
  • Male Posts: 8,707
« Reply #12 on: Feb 10, 2009, 08:07:45 PM »
According to Autozone's company policy they do not... any more.... they got sued for it, and now are not allowed to do it anymore....
kragens also will not loan or scan tools out in CA or HI http://shop.oreillyauto.com//Help/InStoreServices.aspx
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #13 on: Feb 11, 2009, 11:58:07 AM »
Thats nice and all, but I had a code run on my ford not more than 2 weeks ago in vacaville.  Used to have them run all the time in Sacramento, but that was a while ago.  I'm not saying whether they do or not, but its always worth checking.  The worse they can do is say no.
              -Ronald Reagan
Homefries
  • Male Posts: 241
« Reply #14 on: Feb 11, 2009, 01:37:03 PM »
I went the other day to Auto Zone here in OR and they said they still do the scanning but not on my '88.  Too old!
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #15 on: Feb 11, 2009, 01:40:13 PM »
they probably only do OBDII.  Its easy to get the codes from an '88 though.  All you have to do is run a jumper wire (paperclip) between two of the holes in the diagnostic port, and then turn the truck on, and count the flash sequence.  Compare it to the code chart, and you can figure it out.
              -Ronald Reagan
4x4Haze [OP]
  • Turtle Points: 7
  • Male Posts: 337
« Reply #16 on: Feb 12, 2009, 11:57:49 AM »
ok so i checked it again and i got code 71 which i believe is EGR system malfunction, but last week it said bad valve, and a few months before it said 02 sensor. i just dont know which to believe
STTRUE16
  • Male Posts: 10
« Reply #17 on: Feb 18, 2009, 07:19:53 PM »
some of the Kragens/O'Rileys will do it you just have to go in  and talk to them and as far as it throwing out random codes check for a short sometimes they do throw random codes when you have a short in the system
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #18 on: Feb 18, 2009, 10:02:40 PM »
Well, I would probably eliminate the O2 sensor for the time being, simply because of the time frame.  What valve are we talking about?  what code was it?  I can't think of any codes that say you have a bad valve.   You may have a short, or you may have multiple problems.  Are you sure you're reading the flashes right?
              -Ronald Reagan
BAMF
  • Turtle Points: 40
  • Male Posts: 179
  • Member since Jun '08
« Reply #19 on: Feb 19, 2009, 02:39:12 PM »
Pepboys in Vallejo will check you codes but they charge a small fee.  They wanted me to wait in line for 45 mins behind all the other people who were there getting their brakes done and radiators done.  I'm not saying I should be allowed to cut in line but come on, it'll only take 2 mins to read a code.  So I left and bought a code reader at Autozone (who won't check codes).  So anyone in Vallejo, I'll read your code for free. :thumbs:
All tyranny needs to gain a foothold is for people of good conscience to remain silent.
  • Male Posts: 8,707
« Reply #20 on: Feb 19, 2009, 03:49:57 PM »
i bought a cheapy code reader off of ebay for $35 shipped
  • Male Posts: 8,707
« Reply #21 on: Feb 19, 2009, 03:52:00 PM »
i found what i was talking about
http://www.auto-facts.org/disconnecting-check-engine-lights.html
4x4Haze [OP]
  • Turtle Points: 7
  • Male Posts: 337
« Reply #22 on: Feb 20, 2009, 10:38:35 AM »
yeah it flashed 7 times then one time, then the longer pause and did the same code, and i looked the codes up online, not sure it was a reliable source, but i dont know where to get the correct info, maby i can check my chiltons manual but i dont remember seeing it in there, and a short is definately a possibility ive been so busy with work and school i havent really got to tear into it
Last post Oct 15, 2002, 01:02:17 PM
by dan_b
Last post Sep 20, 2005, 12:02:20 PM
by GrimReaper
Last post Aug 24, 2008, 11:08:06 PM
by 1987yota
Last post Dec 01, 2006, 11:26:13 AM
by spacoli
Last post Dec 12, 2006, 01:23:28 PM
by BLACKDOG
