DTB's angry pop up camper
Started by DTB, January 05, 2009, 03:20:58 PM
My mom's poodle/boston terrier mix is 16lbs.. should be around 8-10lbs. she won't lose weight for anything and eats constantly.
but damn 20lbs?! wow... thats one fat dog. lol cute dog you got now Collier.
DTB
Quote from: 85HOrunner on January 11, 2009, 10:33:44 AM
How is that possible unless you feed her?
:talkingn:
Making a person lose weight is hard...a dog is easy...you just control the amount of food and frequency  :biggthumpup:
Quote from: DirToyBoy on January 11, 2009, 12:19:02 PM
:talkingn:
Until he starts knawing on your leg.
:talkingn:
she gets a half cup twice a day.
she doesnt lose the weight. she keeps it on.
it's ridiculous.
DTB
Quote from: 85HOrunner on January 12, 2009, 01:28:51 PM
it's ridiculous.
Do you exercise the dog or does she lay around and sleep a lot?
unclejpl4x4
:offtopic: this ant the PET thread
more angry camper pics
Jordan7118
Quote from: unclejpl4x4 link=topic
=20013.msg668058#msg668058 date=1231801518
x2
DTB
Alright alright...lemme go find something to take pictures of ....sheesh
DTB
The old awning was apparantly ripped off at some point...I removed this in case I want to put a new one on.....Its a ten footer awning channel and awnings are usually 7 feet wide...thats a big awning.
THe previous owner lost the key to the step door so he had been using a screwdriver to open and close it  :shake:
THe aluminum is cleaning up nice....and look at that canvas!! It IS actual Carhart material....pretty cool.
  :king:
Underside starting to look better
She's gettin there...
Sweet, get a wider axle, some fender flares and slap some 35's on it.
unclejpl4x4
i see rust in that frame   U should pull off the camper and fix that.
O and isent bad luck 2 pop your camper in side :dunno:
J/K  i want one now
Only if you forget to lower it and take it out of the garage, or should I say try and take it out.
unclejpl4x4
is that like puting a lift on a truck then realizing you can't get it out of the garage
DTB
Quote from: unclejpl4x4 on January 12, 2009, 04:06:19 PM
J/K  i want one now
Its just surface rust...there is actually paint underneath it
Jordan7118
Cool. Are you gonna wire up the brakes? Do you think they work?
DTB
Quote from: Jordan7118 on January 12, 2009, 04:17:36 PM
Yea Im gonna get em wired up.....I had some mag mount ones on top for now....I did get one side to work and the liscense plate light when I plugged it into my truck
Jordan7118
I meant BRAKES, not BRAKE LIGHTS  :smack:
Is that what I see on those drum brakes?
DTB
oh right..those.....yea i am pretty sure they work ok...I took em apart and cleaned em up.......i just dont have a brake controller and am not even sure if I need them
Jordan7118
Ahhhhh... I c...
I'd want 'em if it were me, then again I'm scaredy...  :outtahere:
Duffil
how about you add a shackle in your suspension on that pig? it should help with the :bumpinbutts: that always happens in a 70s rig like that.
the two wires are not ebrake, they are electric trailer brakes, one is hot, the other is ground, goes to the frame.
DTB
Quote from: Duffil on January 12, 2009, 09:34:11 PM
It's a "slipper style" leaf spring....seems to work pretty well for what it is.. The end of the spring slides back and forth in a mount when it flexes
also...by "ebrake" he really meant "electric brake"   :biggthumpup:
We'll see how she tows first...
Duffil
oh that pic must be taken from the  back then. I am familiar with that spring setup just couldn't tell that's what it was.
DTB
#83
I made this homemade tire leveler out of 1 x 8"
I aint no carpenter but it still turned out ok....
I picked up this cheap awning.....
Should match with my new paint scheme too..
I also started disassembling the lock and rebuilding the door where the previous owner had mangled it.
Your leveler is too dang long. My motorhome has shorter ones than that and has a much larger contact area.
DTB
Quote from: Rocksurfer on January 13, 2009, 05:46:50 PM
It's really not that long....each section is just under 12" long....its about 3 feet long total
My entire leveler is about half of yours. Each step is just long enough for my tread patch.
DTB
Quote from: Rocksurfer on January 13, 2009, 05:54:52 PM
hmmmmm......  :cheese: ok....maybe i will remake it......i need to save all the weight i can
Take the 1st step off and shove one between the 2nd and 3rd, that should be perfect.
Quote from: DirToyBoy on January 13, 2009, 06:23:41 PM
for that little popup get the plastic lego style levelers
