lets call her wheely
Started by 83yota, January 22, 2009, 05:57:11 PM
83yota
well i got an 85 4 runner. i am not acctually going to get to touch it untill the 8th or 9th of feb but i am starting planing now. it is bone stock except for the 4.70 kit and the rock sliders. he is giving me a new set of allpro 4" ft springs and 2 sets of 63" chevys. i am going to paint it OD green with WWII insignia slightly modified. her name will be wheely to go with the willys theme i am going with. i will build my own ft and rear bumpers. for now it will be a dd but in a few years it will be trail only and it will have a small block in it.
83yota
this is the sceme. each thing means something. by the way i am no artist
Steve_925
the paint scheme is gonna look sick. i love the drab green with white stars. thats what my jet ski looks like
UA 342
STEAMFITTERS
83yota
thanks i am ready to get started
83yota
well i have a line on another t-case. will it hurt anything to run duals in a dd?
Steve_925
nope. may need a CV rear shaft if you have a lot of lift. or if your going to
UA 342
STEAMFITTERS
unclejpl4x4
??? if you name her wheely U got make her do wheelies :dunno:
Steve_925
UA 342
STEAMFITTERS
83yota
like i said one day i plan on a small block fuel injection and link ft and rear so by then i hope to be able to do wheelies or wheelys in this case
83yota
4" of lift is the plan for now. remember i need to keep it as a GOOD daily driver
KYOTA
is the 'tp35' over each wheel well so you remember the tire pressure?
pumkin toy
97 4runner Limited
83yota
to be honest yes. it is so all the "special"  :therethere: privates in WWII would remember. so that is what i am going to do. tring to keep it as authentic(sp?) as possible and yes i know it is a toy not a jeep
83yota
so how much lift will the chevys give me? will i need a block or anything like that to make it level with the 4" allpro rears? what size tire can i expect to put on with this setup?
83yota
83yota
well i got her out and i love that 4.7 set i have some good pics BUT the thing says my pics are to big. i still stuck tring to figure out what i am going to do with the drive train. now the question is what gears should i run if i want to run 33s for now. also with 4" of lift will it clear 33s with VERY little to no rubbing (12.5 wide) and what off set do i need to run them?
pumkin toy
Quote from: 83yota on March 19, 2009, 07:05:52 PM
33's will clear with no rubbing on a 4" lift.  i had the same setup on an 86 runner and never rubbed at all. i had 33x12.50x15 BFG mud terrains on 15x10 wheels with the normal 4.5" backspacing. as far as gears, 4:88's would work fine but if you plan on ever going with bigger tires you might as well install 5:29's the first time around.
97 4runner Limited
83yota
if i ever go bigger i WILL be putting 60s under it for sure but for now 33s are it.
pumkin toy
i would probly stick with the 4:88's then
97 4runner Limited
83yota
cool thanks any ideas how to down size pics so i can put them on here?
83yota
stock flex
38s with no lift anyone?
83yota
top of the humvv test ramp
4.7s hubs unlocked and a humvv test ramp...  no prob
paint almost done now onto the emblems
pumkin toy
looks like you got the pictures figured out!  runner looks pretty good in green.
97 4runner Limited
unclejpl4x4
83yota
thanks. but i have decided to sand the entire runner down again and repaint. my good friend owns a VERY nice custom body shop and a little while back he restored a military jeep and has a fair amount of OD green and flat clear that i can just pick up. so hopefuly by the end of the month i will have the paint totaly complete with emblems.
83yota
here is the ft bumper it is VERY simple but like it, what do you think
pumkin toy
very simple but it will definately take a hit better than the stock one!  you need to weld some rings onto it to hold shackles, so you can pull jeeps out!
97 4runner Limited
83yota
i know i also want to box it to make it a little stronger
