LILBUDDY's 89 Build (Built a bumper 5/17/09)
Started by lilbuddy, January 16, 2009, 10:27:01 PM
0 Members and 6 Guests are viewing this topic.
lilbuddy
#181
Well bunch of new stuff.
Got the new motor in. I also got the injectors fully cleaned and resealed. Truck runs great. Was able to go 75 up hill and hold 4th and 5th. Wheels pretty awesome. I do need new valve stems in 3 tires though. On that trip though the steering box started puking so i need new seals. Oh also my truck sounds like a damn Acura Integra now that the motor runs good and i have that K&N intake, its ridiculous. Its so loud
  • Within the next week or two the duals are getting put in.
  • Next monday bed is getting bobbed (i think)
  • Sterering box should be getting drilled and tapped soon for my hydro assist
  • And just now i ordered up a new Sky manufacturing xmember so that should be here by next week also.
  • Probably going to pull the steering box sometime next week, pull the drivelines at the same time and buy some sch. 40 and make new ones thatll fit with the duals.
  • Getting new tail lights SOON since a 47" LTB took out my driver side.
Should be pretty legit
RIP Kyota.... you are the man
GET IT!!!
lilbuddy
Heres the clean injectors. I didnt take pics of anything else because its just a standard 22re in a 3rd gen engine bay.
Also the speedo works now, jsut jammed it on the back of the cluster and its holding. Stereo was semi broken but i fixed it. Heater core works on and off, just needs a major flushing now.
EDIT: I actually recommend anyone that has a truck that sits a lot, high miles or anything like that to get the injectors cleaned/resealed. I noticed a huge amount of power between both motors.
GET IT!!!
wampum
That's sick, how much did it cost to get the injectors done?
1985 EFI Xtra Cab -> http://board.marlincrawler.com/index.php?topic=50415.0
1993 4x4 22RE
lilbuddy
Quote from: Wampum on February 25, 2009, 07:06:32 PM
$100 from napa on 20th st in Chico.
Half the price of what LC Engineering charges and they do the SAME things at napa.
GET IT!!!
yota_krawler
I might need to look into that. My motor has like 2 hundo on it and I dont know when the injectors were last changed or cleaned etc. It also sat for a year. I cant feel any difference in my efi than with my carb... Plus the 4runner has a legit exhaust and header. plus and electric fan and k&n filter.
twistedtoy92
we have a injector cleaner at the shop....
lilbuddy
Starting to bob my bed today. Probably going to park it and get the seal kit for it later if i have time. If not tomorrow.
GET IT!!!
yota_krawler
sweet, I want to see it. I went up to inskip last night. DOOOOOD the 4runner did SHITTTTTTY. I could barley get up to the air down spot. I dont have the lockers and gears in yet and I was running at street pressure.
kiyul4130
did you start on it in the garage? the weather is horrible.
-kiyul-
ECV 7-11
KYOTA FOREVER
86bobbedtoy
Quote from: Y_K on March 01, 2009, 04:50:08 PM
dont feel bad,
I think it would have done alot better with some kind of rear locker.
lilbuddy
Quote from: kiyul4130 on March 01, 2009, 05:12:22 PM
Yeah i pretty much only have half the welding left to do..
Took about 2hrs to totally do it and it lined up rpretty legit. Especially doing it myself.
Ill post pics in a little. Looks sick.
GET IT!!!
lilbuddy
GET IT!!!
yota_krawler
4runner17
NorCalToy
:flamer: IFS
lilbuddy
GET IT!!!
toyotanner
i always look forward to the bobbed beds you do haha... turning out good :thumbs:
TIMS89CRAWLER
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
Jud
When I get the cab and bed swap done I'll have to roll up there one day and we can bob my :pokinit:.
Oh and what sub if any are you running in there?
I'm trying to figure out if I can fit a 12" behind the seat of the single cab.
"bout tree fiddy"
lilbuddy
Quote from: toyotanner on March 01, 2009, 11:08:55 PM
thanks dood.
Quote from: Jud on March 02, 2009, 03:45:39 AM
Its a 10. It hits pretty good. It even hits the lows decent for being a small box. It is fiberglassed though so that helps.
I was going to put my 12 but in order for it to fit itd need a 1.25 cu ft. box which is big and woulda taken up practically the whole seat.
GET IT!!!
88Rokyoat
lookin good! Pat and I might make a run up the snow this weekend. Im hoping to have my junk ready by Sat. It should be... are you down?
stupid people shouldn't have kids.
lilbuddy
Quote from: 81rokyoat on March 02, 2009, 10:16:15 AM
I need a new seal kit for my PS box.
I work saturday so i couldnt go then. I could go sunday. I think pat (ramrod) is comin up with his truck  and they may go on sunday, not sure though what theyre doing. If I can find a new box or get mine resealed ill be down.
GET IT!!!
88Rokyoat
cool. I am still waiting for the FROR t-case plate so I can build the crossmember. if I get that built (I should!) Sunday would probably work...
ToYocRawleR
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
Jud
Quote from: LILBUDDY on March 02, 2009, 09:07:54 AM
I was going to put my 12 but in order for it to fit it'd need a 1.25 cu ft. box which is big and woulda taken up practically the whole seat.
Ok. I'm gonna try and run a 12" Alpine Type S. The air space for those aren't that big really.
I may have them make kinda a center console with the sub firing at the back wall. It's not gonna be ported either.
"bout tree fiddy"
yota_krawler
I had a 12 in my extra cab, it hella filled that cab up with bass. I ended up going to a 10 cause it was over whelming. I dont have one anymore.
Do you have the 12in alpine in your 4runner? If so, how does it do. I need to go speaker shoping but I dont know what to do. I may do one 12 or 2 10s...
46&2
11" is the perfect amount to take out. looks good
lilbuddy
GET IT!!!
88Rokyoat
I just thinking if you havent got a seal kit for the PS box, I got one from a place in Or. it was like $50 , patterson wanted like $65... shipping was fast too.  just throwin it out there... http://www.prosteering.com/k_toyota_truck.htm
