Author Topic: HYsteer question  (Read 3076 times)
olemisstoy88
  • Turtle Points: -381
  • Male Posts: 521
  • Member since Dec '05
HYsteer question
« on: Jan 04, 2009, 01:50:20 PM »
I have 3.5" lift with a solid axle toy, can I use front shackles to lift to 5 or 6  inches in front? if so how long to they need to be and where can I find them? or before ya'll say it should I just get a 6inch pack and shock hoops? and all that.
I want to get Histeer  as my next project but I have to have 4 inches min, right?
88. 4x2  Total chaos 6.5" caddy uniball kit  Racerunner 2.5 x 14" coilovers on front, 62" deavers, fabbed engine/shock cage, bed cage, roll cage and great frame, complete int., (5) 5x4.5 outlaw II w/235 buckshots <----- parting out! make offer
'84 4x4 . 5 speed 22r  3.5" lift  33x10.5s bfg MTs  Hannamann Glass frontcap, 32/36weber, LCE swirlie plate, Magnaflow,
"Im madder than Toby Keith at a Dixie Chicks concert"
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
Re: HYsteer question
« Reply #1 on: Jan 04, 2009, 03:17:04 PM »
You can do whatever you want !  About 2 " of shackle for about 1" lift.  Your shackle angle could get worse but who knows.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #2 on: Jan 04, 2009, 04:51:49 PM »
All of the shackle lift in the world is not going to change how the axle is going to sit on the springs. When they say you need at least a 4" lift, they are talking about the springs. What type of springs do you have to get 3.5" lift?
Mavericks
  • Turtle Points: 2535
  • Male Posts: 256
  • Member since Apr '08
« Reply #3 on: Jan 04, 2009, 08:45:46 PM »
if you want to keep 3.5 inch lift springs just get some 2 inch longer shackles and you'll have room for highsteer.  I would just make sure and mount the steering box as far forward as you can for when you do get new springs and shock mounts.
1985 toyota SR5, 22re,  5.29's locked front and rear, duals with twin stick, longfields.
OOPS
  • Male Posts: 2,561
« Reply #4 on: Jan 05, 2009, 09:30:21 AM »
How do you figure that, moving the back of the springs down will not change how the axle is going to sit on the springs. All it is going to do is to chance the pinion and caster angle.
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #5 on: Jan 05, 2009, 10:26:02 AM »
When they state min 4" of lift needed, it's so the TRE doesn't collide with the oil pan.  A longer shackle would help in this case.
I've got 2.5" of *lift* My TRE hits the Pan on full compression.  A longer shackle would move the pan further away from the TRE.
At least that's how I understand it.
All_Set
  • Male Posts: 543
« Reply #6 on: Jan 05, 2009, 10:36:46 AM »
You'll need 2" of shackle to lift the truck 1".  So, ~5" of additional shackle length to raise it 2.5".  This should make for an extremly long shackle.
82 HiLux
  • Turtle Points: 81
  • Male Posts: 750
  • Member since Dec '06
  • its beer thirty!
« Reply #7 on: Jan 05, 2009, 03:11:52 PM »
look into a front drop hanger along with a longer shackle
www.sky-manufacturing.com sells a 2" drop front spring hanger
REG535
  • Turtle Points: -287
  • Male Posts: 1,083
  • Member since Jul '07
  • Shes traveling to many celestial worlds
    • Buy me a cigar
« Reply #8 on: Jan 05, 2009, 03:14:56 PM »
would a body lift work with shackle length?
82 HiLux
  • Turtle Points: 81
  • Male Posts: 750
  • its beer thirty!
« Reply #9 on: Jan 05, 2009, 03:16:46 PM »
Quote
:headscratch:
olemisstoy88 [OP]
  • Male Posts: 521
« Reply #10 on: Jan 05, 2009, 03:35:20 PM »
na a body lift is not gonna help, I might go with the drop hanger and shackles, or just a set of new springs. I got the springs from a 4wheel place that went out of business he in my hometown. they were rough country. the whole lift was only 100 bucks. could not pass it up. shocks and front springs. hardware and ubolts complete lift for a bill.  its a 3.5 in lift I have blocks in the rear and I want to get rid of those asap, lol.
Mavericks
  • Male Posts: 256
« Reply #11 on: Jan 05, 2009, 08:44:36 PM »
new springs would be the best option.   Post up some pics if you can.
OOPS
  • Male Posts: 2,561
« Reply #12 on: Jan 06, 2009, 08:24:10 AM »
OK my thinking was in the wrong direction on the clearence issue, sorry. While the longer shackles will help you out, if you go to long it will mess up your pinion and caster angle. Then if you go to correct it with shims the tierod will be hitting the springs.
93yoda
  • Turtle Points: 7
« Reply #13 on: Jan 07, 2009, 10:18:22 AM »
I only have about 1.5 of lift and my steering doesnt hit the oil pan. It just takes alot of planning....
All_Set
  • Male Posts: 543
« Reply #14 on: Jan 07, 2009, 11:16:21 AM »
Link to your build?   I would love to see that.
olemisstoy88 [OP]
  • Male Posts: 521
« Reply #15 on: Jan 08, 2009, 04:21:39 PM »
what?  no way.....
Last post Aug 12, 2002, 10:52:26 AM
by hawaii500_1999
Last post Jul 23, 2005, 07:32:16 AM
by Matty
Last post Jun 30, 2006, 08:55:53 AM
by yotadork83
Last post Aug 15, 2006, 10:20:31 AM
by BigMike
Last post Dec 26, 2007, 08:02:23 AM
by Gewehr43
