Author Topic: transfer transmission crossmember skid plates  (Read 10779 times)
bigtow
  • Member since Sep '08
« on: Oct 07, 2008, 08:24:22 PM »
going to  be building one soon does anyone have pics and ideas for a first gen long bed thanks
4x4Haze
  • Turtle Points: 7
  • Male Posts: 337
  • Member since Feb '07
Re: transfer transmission crossmember skid plates
« Reply #1 on: Dec 05, 2008, 06:56:37 PM »
i got mine from trail gear and it works great
A jumper cable walks into a bar. The bartender says, "I'll serve you, but dont start anything."
joeshmo
  • Turtle Points: -34
« Reply #2 on: Dec 17, 2008, 08:42:19 PM »
build a flat belly
Talon84x4
  • Turtle Points: 375
  • Male Posts: 919
  • Member since Mar '06
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
rockwalker
  • Male Posts: 280
  • Member since Jun '04
« Reply #4 on: Feb 01, 2009, 06:30:39 PM »
heres mine
85 runner with 3RZ  linked  locked  and ready  2rock
http://board.marlincrawler.com/index.php?topic=40729.0
87 tintop..........................................................
NorCalToy
  • Official Super Badass
  • Turtle Points: 77
  • Male Posts: 2,472
  • Member since Jun '07
  • IFS no longer! - Member #8342
« Reply #5 on: Feb 02, 2009, 11:04:19 PM »
got any pics of it mounted up rockwalker?
:flamer: IFS
mtm
  • Male Posts: 58
  • Member since Nov '09
« Reply #6 on: Aug 04, 2010, 05:40:00 PM »
this is an old thread but heres the one on mine and some pics of the ones i make up for hpoc club members
hilux 82 with mk3 2.4d engine. bobed 18 inches, full soft top, 9 inches of lift,exo cage,swing out tyre carrier, front tube winchbumper with x9, rock sliders, rear tube bumper, front truetrac and rear arb lockers, twin trans adapter with 4.7 crawler gears,20 forward and 4 reverse gears, 38 inch super swampers , rear disc brake conversion, trans disc parking brake, 5.29 r&p ,rear bench seat,hand throtle,custom storage boxes, custom made snorkel,onboard air compressor,cb twin bateries,split charge system, diff guards, low profile gearbox mo
NITE KRAWLERS
  • Turtle Points: -35
  • Male Posts: 970
  • Member since Oct '09
  • I KNOW A SWEENEY BRO!!!
« Reply #7 on: Aug 25, 2010, 09:15:58 PM »
This is mine and its been working great, but next one i build the mounts will be up inside the frame rails so i can slide on the frame!!
Sometimes life is a rock an we need a Yota to get over it an Chevy is like a rock so I'm over it!!!
theslayer85
  • Turtle Points: 83
  • Male Posts: 300
  • Member since Dec '10
« Reply #8 on: Jan 13, 2011, 11:37:04 AM »
Not to steel the tread but I want to build a crossmember too.  I really like this crossmemeber.  To mount this do you use the factory rubber mounts that normally go into the overkill factory crossmember.  I recognize the holes in the bottom of the plate i am just unsure how the transmision is mounted from there.  Do you have any pictures of the acctual mounting portion?
theslayer85
  • Turtle Points: 83
  • Male Posts: 300
« Reply #9 on: Jan 13, 2011, 11:41:54 AM »
I really like how this guy build his crossmember.  http://board.marlincrawler.com/index.php?topic=76686.0
R.DesJardin
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
« Reply #10 on: Jan 13, 2011, 08:56:38 PM »
Here's mine, dual cases, MC07R10. The build link and a couple pics..............
http://board.marlincrawler.com/index.php?topic=71559.0
R.DesJardin
mtm
  • Male Posts: 58
« Reply #11 on: Jan 18, 2011, 12:35:37 PM »
the xmember uses the std trans mount and bolts up to the factory mounting holes
theslayer85
  • Turtle Points: 83
  • Male Posts: 300
« Reply #12 on: Jan 18, 2011, 02:34:20 PM »
Hey thanks those pictures do help.  I take it the welded plate in the middle is to raise the 4 little bolts that go into the rubber mount on the transmission itself up so they are protected from the rocks, or is it just extra thick to take the abuse?
R.DesJardin
  • Male Posts: 489
« Reply #13 on: Jan 18, 2011, 06:00:30 PM »
Better pics, the recessed plates to protect the bolts. Rear case is rotated 10deg, MC07R10.
R.DesJardin
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Member since Aug '10
  • Get Some
« Reply #14 on: Jan 18, 2011, 06:28:51 PM »
This is my twin case skid plate , I don't know who made it !!
mtm
  • Male Posts: 58
« Reply #15 on: Jan 26, 2011, 03:37:18 PM »
the small plate in the middle is to keep the lowest part of the trans case from knocking on the xmember and alsow alows the bolts to be resessed to keep a flat bottom
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #16 on: Jan 26, 2011, 04:43:34 PM »
You haven't mounted it yet ?
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Get Some
« Reply #17 on: Jan 27, 2011, 04:52:18 PM »
No not yet, I'm building a 4.7 case and doing a little pinstripe on the bottom !
Thanks for hookin me up on this crossmember Kevin , ill post some picks as soon as stuff starts coming together !!    :beer:
GAP3RKi113R
  • Turtle Points: -3
  • Male Posts: 33
  • Member since Apr '11
« Reply #18 on: May 08, 2011, 02:37:23 PM »
Sick
Eat Sleep TOYOTA
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
« Reply #19 on: May 08, 2011, 02:49:27 PM »
No problem, gotta help a brother out.
Building this one, still got the back half to do.
bigtow [OP]
« Reply #20 on: Mar 21, 2012, 09:28:38 AM »
thanks guys this really helped
Last post Feb 16, 2005, 11:18:36 PM
by mudaddict
Last post Feb 14, 2007, 04:39:37 PM
by mojavehanna
Last post Jun 11, 2007, 12:55:13 PM
by 98taco4x
Last post Nov 25, 2013, 10:06:22 PM
by garlicgabe
Last post Nov 13, 2021, 05:49:18 PM
by Wainiha
