The skid plate might be pricey but they are a lot cheaper than fixing a replacing the drivetrain that it is protecting.
http://www.budbuilt.com/new/ifs.html all the way Drew
I don't have the IFS skidplate, but I am a budbuilt customer. No question about it. Great products, great customer service.BD - what's your logic for speed holes adding strength?
i think they use a dimple die. its makes a little cone kinda shape and makes a thinner peice of metal more ridged. the baja guys use this to make strong light partsDrew
ya, I just forgot what the die is that is used. Here's a pic of the die and the holes it makes. by creating that flare around the hole, it spreads any pressure on it across more than one plane, which makes it stronger. That would actually be a concern of mine with the budbuilt one, but with 3/16" you probably won't be denting it to badly. Having the holes does allow for using lighter metal, I think mine is probably 16 guage steel, and it is strong. Several people on the board have seen me come down on that thing HARD, and it doesn't do a thing
Interesting. I'm going to have to do some reading on that. I can see it being stronger than a drilled hole, but it's hard for me to believe that it's stronger than a solid plate.
Bend a 1" x1/8th" piece of strap, Very easy with it flat, very hard with it standing up.
Ignore the rig its on, but this is a pro comp skidplate. They're money, but they are strong Its got those "speed holes" pressed into it, which actually gives it a lot of strength. I've come right down on mine, and not done a thing to it. Check trailmaster and superlift as well, I know trailmaster used to make one, and I don't know about superlift.My truck with it
It seems 3/16" is the only thickness that Tacoma skidplates come in some. The only problem I see with some of these skidplates is if you lift your vehicle to the point were you need diff drop kit you are S.O.L. If that is the case it makes my suspension choice very very easy.
Your kidding right? Pro comp skidplates are pretty much only for show, and as far as I know only work with their drop bracket lift kit... stay far, far away from these. If you want an actual skidplate for an IFS tacoma check out budbuilt.com they have a really good setup consisting of a very beefy and well thought out front, intermediate, and belly pan skid system that will take a ton of abuse while protecting your vehicle. I have lots of experience with these and they are worth the money.
Those type of skids are a joke, Ive seen them destroyed on several runs. They wont hold up to rocks like a budbuilt system will.
Budbuilt front skids are 3/16" steel plate that gains rigidity by the side pieces being bent at a 90 degree angle from the horizontal plane. The front skid alone weighs about 70 lbs. they are not light but they do what they are supposed to do.
Started by Weldo Engine
Started by denio Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by bigtow Bumpers, Cages, and Tube Benders
Started by BABYTOYOTA Parts For Sale
Started by Wainiha General 4WD Discussion
