to bob or not to bob a long bed toyota?
Started by 82bigbird, September 18, 2008, 11:36:42 AM
82bigbird
does it sound stupid to bob a longbed toyota or is it worth it?  :crossed:
jonathan82toy
I think it looks way better on a long bed... Check out my avatar pic   :eyebrow:  Start  :flamer:
What Is The Truth Behind The Magic Turtle Breeding Program?
S.S. More Powerful Than Superman, Batman, Spiderman And The Incredible Hulk Put Together.
Duffil
TheCookieMonster
do it  :thumbs:...its definetly worth it  :beerchug:...pretty much the first mod i did to my truck
toyyota
Do it, Long beds are easy to come by if you dont like it.
blackdiamond
To Bob or Not to Bob, It's Not Even A Question.
You'll never regret it.
I don't know what do you think does this bobbed longbed look cool? You can take your time to answer there's no rush think about it and get back to us.
Ttruck
bob it.  I ran mine as a longbed for over 3 years and finally decided that it just wasn't cutting it.  I would drag ass on just about everything.  I finished the bob on my 84 last weekend.  took out 12 inches out of the bed and 5 off the frame.  I'll post some pictures this weekend.
maybe turn this into a bobbed longbed thread.  maybe others will post some pics.
mudmaster
Time to go wheelin!
rednk1980
Imo long beds that are bobbed look better than a short bed bobbed but thats my  :twocents: heres what mine looks like
halfxspaid
Ill play devils advocate here...I was going to bob my longbed but decided against it.  I built a 1/4'' rear bumper that acts as a slider.
Wheeling with this setup does not affect me AND the best part is I can always bring tons of gear/firewood!
85 longbed - Caged, locked, dual'd and armored
blackdiamond
Quote from: halfxspaid on September 19, 2008, 03:14:52 PM
Marlin's truck used to be this way and I thought he said bobbing the truck was the best mod ever and didn't know why he had waited so long.
95SAS
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
twistedtoy92
bob it!!! i'd much rather have a bobbed bed!!!
Tool Pimp
DO IT!!! and Dovetail it while your at it   :yupyup:
but I must say shortbeds are the way to go  :sly:
montanatoy
Bob it looks killer when done here is mine took out 12 inchs
toyotas are like tonka trucks of old built to beat the hell out of
REG535
I never understood it fully, when you cut the bed, what do you do for the frame? You let stick out or what? If you cut it how on earth do you put longer springs on when you have move the shackle back farther?, I've always been confused about this modification.
Duffil
Quote from: ToxicToy on September 20, 2008, 03:45:48 PM
there is room on the frame to cut off 5" or so and still have 2" behind the stock mount. It all depends on how much you want to take out.
twistedtoy92
and you can always mount your shackles on the back of the bumper when you box the rear of the frame!
blackdiamond
On my 85 extended cab I cut 13 inches out of the bed and I believe it should be similar from the frame back to a long bed (?) if the main difference is in the cab/front of the bed.  If I were to do it again, I would have made the cut a few inches less for additional room and I doubt it would have made much difference off road.
95SAS
i cut 14 inches out of mine, my frame sticks out about 2 inches with the rear shackle hanger moved.
my build
Ttruck
from my earlier post, here are some pics, before and during.  I too thought that keeping the longbed for storage was a good idea until I brought stuff I didn't really need and carried way too much weight.  I also had the bumper that I let drag, that ended up just causing issues.  so I cut it all off.
Ttruck
here are 2 pics of it done.....
looks good, you only need a 6 ft bed anyways ;)
Ttruck
yep, exactly.  I'm pulling the truck box and getting a different tote to use the space differently......looking to pack more efficiently and packing less.
Notmyboyfriendstruck
Reading this made up my mind. I'm definitly bobbing my 84 lonngbed. Thanks!
SwEeT d
"A dirty truck is a happy truck"
the_white_shadow
Stupid NOOB question. What is the best tool for cutting the bed? I think a jig-saw will make the straighest cuts. What did yall use? Sawsall? Cutoff Wheel?
Thanks,
Alex
Tool Pimp
Quote from: the_white_shadow on November 03, 2008, 11:16:29 AM
Thanks,
Alex
I used a cut off wheel, my buddy used a sawsall but it shakes the sheet metal to much.  just my .02
al76
Quote from: Tool Pimp on November 03, 2008, 11:26:47 AM
The ? is when are you going to do mine? haha I always have to ask you
F**k Idacurt
Tool Pimp
bring it up  :cheese: Ill cut the hell out of it  :beerchug:
