0 Members and 28 Guests are viewing this topic.
What is wrong with this one's engine?
So, what is wrong with this one's engine? How many miles are on it?
x2
so whats up with this motor
okok calm down a tad now...something is up with the 6th cylinder real low compression, but its not throwing the check engine light... i think its the original motor with...278 on it, no marks at all on the pull hooks for the engine, whereas the truck you could see had marks from sliding around on some hooks, but real clean. ill take some interior pics in a bit, gonna get an engine for it next weekend i think. so then well be cherry and good until i can get some money for bigger tires then cases, then SAS at somepoint in a long ass time.
only #6? why buy a motor? I'd be guessing its a HG. What're the compression #s on it? did you throw some oil in there when you did it?
i say pull the motor, replace gaskets with TOYOTA gaskets, use ARP head studs
because tahts what my brother (mechanic) wants to do, it works for me because then ill diagnose and redo as needed to the original engine and then if in some situation where the V6 does somethings stupid, ill have a spare engine sitting right there.and to appease you, ill see what i can do to get a compression test done tonight, although my brother kinda F'ed up the tester. i see. ill talk to him tonight and see what he says.thanks for the niput guys
alright so im lookin at gettin an engine from a 92 runner, everything is a direct swap and there is no extra wiring or anything that will need to be changed?
the engine i may be getting is from a member on here. but what makes you believe its only HG?
There is a lot more to setting up a PROPER 4-link on a DD rig than most people think. I will leave it at that. Good luck.
I love the factory sized spare on the back of it It is a pretty cool runner (for a 2nd gen), what all is involved in getting rid of the y factory 4 link? Just cut off and weld on leaf hangers and shackle tubes or whatever? Is that it?
Started by PoorRunna Parts Wanted
Started by 84runner Chit Chat Camp
Started by BLUCRUZ « 1 2 3 » Engine
Started by lal357 General 4WD Discussion
Started by gmrwizard Engine
